1. PlanetPluto7's Avatar
    Anyone seeing bad Bluetooth? I had the Note 3 where Bluetooth was fine. My 4 can't hold a connection past 20 feet; fails to connect to my car speaker without scanning and drops connections. Is mt phone a dud or is the 4 really bad?
    12-19-2014 04:29 PM
  2. Rukbat's Avatar
    It depends on the device and the area. There are 3 classes of Bluetooth:
    Class 1 is 100mW, and the range is about 100 meters in clear air.
    Class 2 is 2.5mW, and the range is 10 meters.
    Class 3, like headsets, is 1mW, and the range is 1 meter. That's in clear air. If the phone is in your left pants pocket, and the earphone is on your right ear, that's about 3/4 meters through human muscle tissue, and WAY past the range of a 1mW 2.4GHz signal.
    If you want more than 20 feet (just over 6 meters), you need a Class 1 device. Since car radio BT is designed for a phone that's inside the passenger compartment, and usually pretty close to the radio, it's probably a Class 3 devide. Maybe some of them are Class 2. But that's through plastic and surrounded by metal, so the range would be less. Once you get outside the car (how else do you get 20 feet from the car audio system), you're talking about getting signal through a conductive enclosure - not something BT (or wifi) is designed for.
    The problem is mainly that you're trying to use a system for something FAR exceeding its design specs. (Maybe your Note 3 had an exceptionally sensitive receiver - the sensitivity still varies from chip to chip - and probably isn't one of the things measured under exceptional conditions, which is what you're doing. [The sensitivity can fall off a cliff at one point, so if you're one inch too far, you go from good signal to no signal with digital signals. The measured sensitivity - wire to the radio - can be fine, but the sensitivity at twice the design spec can be nil.])
    BrockS. likes this.
    12-19-2014 04:50 PM
  3. Jon Jackson's Avatar
    Mine seems about as good if not better than my S5. I've only used it for my JBL flip though....
    12-19-2014 04:52 PM
  4. MightyMike's Avatar
    Mines great. Mine will pair with my aftermarket rf Bluetooth adapter in my Jeep when I'm in the house..it's 4.0 Bluetooth. Works great!
    Sent via the Next Big Thing, My Galaxy N4
    12-19-2014 08:11 PM
  5. Almeuit's Avatar
    Mine has been great. I can walk all around my desk at work and I don't have an issue.
    12-19-2014 08:13 PM
  1. Replies: 3
    Last Post: 07-28-2016, 11:41 AM
  2. Avoid poor connection option missing.
    By tonyr6 in forum Android 5.0 Lollipop
    Last Post: 12-20-2014, 01:33 PM
  3. Replies: 2
    Last Post: 12-19-2014, 04:56 PM
  4. Do I need to back up photos on Google Drive and Lookout?
    By Debbiesue49 in forum Memory (RAM)
    Last Post: 12-19-2014, 04:22 PM
