1. kris2pe yu's Avatar
    I don't get it!
    This thing is BRAND NEW!
    I turn on powersaving mode.
    Close all apps in background after using it.
    I don't get it! I drinks battery like water!
    12-23-2014 10:03 AM
  2. Rukbat's Avatar
    Fully charge the battery (like overnight). Use the phone until it tells you to charge it. Do that 2 more times. Then fully charge iit and see how it acts. If it's still draining the battery in a few hours, have it replaced.
    12-23-2014 10:13 AM
  3. Almeuit's Avatar
    We would have to see your battery stats to help you.
    12-23-2014 11:16 AM
  4. LaTuFu's Avatar
    The first day or two that you have the phone, battery performance is not good. Especially if you are coming from a previous Android device and you selected "update apps from google account." You basically gave your google account permission to sit there and download a whole bunch of stuff in the background for the first few days. If you didn't take the time to set up all of your accounts and how they interact with background updates, there is a good chance one or more of your apps are constantly waking up to check for updates, new messages, etc.
    In other words, there are a lot of possibilities before you can say "it is the phone."
    Like Almeuit said, we need to see your battery stats to know more. Look up the countless other battery stat threads in this forum and you'll see what screen shots we need to help you.
    12-23-2014 11:28 AM
  5. kris2pe yu's Avatar
    I have tried turning off alot of things hopefully things will improve after but this is the screen shot if you guys can help me out that would be nice.
    Attached Thumbnails Why does Note 4 drains battery way too faster?-screenshot_2014-12-24-00-58-24.jpg
    naira1 likes this.
    12-23-2014 12:11 PM
  6. nyc_rock's Avatar
    How long is that off the charger?
    12-23-2014 12:25 PM
  7. naira1's Avatar
    Show us your screen on time as well as the battery graph so we see how often the phone is awake. It could be a rogue app
    Sent from my Nexus 10
    12-23-2014 01:03 PM
  8. dpham00's Avatar
    We would need more detail - drain doing what? Screen off? If so take a look at wake locks. If screen on, what apps are being used, data location services, screen brightness.
    Apps like gsam, battery monitor widget and wake lock detector can help.
    Sent from my Verizon Samsung Galaxy Note 4
    12-23-2014 01:05 PM
  9. Rmedy21's Avatar
    I don't get it!
    My battery is not fairly new. However my battery has been draining a lot faster then it should.
    Amazing Verizon Galaxy Note 4
    12-23-2014 01:16 PM
  10. Almeuit's Avatar
    What is the time off battery?
    12-23-2014 03:21 PM
  11. LaTuFu's Avatar
    Again, check out the many other battery life threads in this forum and you'll see the screen shots we need in order to help you.
    The one you posted isn't enough to give us an idea.
    12-23-2014 05:29 PM
  12. currentdroiduser's Avatar
    If u play games or watch video the battery drains real fast
    posted with my note 4
    12-23-2014 06:11 PM
  13. jey8100's Avatar
    I had the same problem with my battery draining fast I simply turned off the location services (GPS). Maybe taking it off high accuracy may work as well, anyway this made a huge difference in my battery life. The question that I still have is weather the draining is due to the Location service it self or weather there is an overzealous app that is causing the drain on the service. Regardless only turn it on when needed you will be much happier.
    02-09-2015 08:58 PM
  1. allergic to contactpoint forr the battery
    By Joke Adema in forum Samsung Gear S
    Last Post: 08-06-2016, 02:53 AM
  2. Why is Deezer no longer working on my S5 lockscreen?
    By Pidgery in forum General Help and How To
    Last Post: 01-11-2015, 08:46 AM
  3. battery drain from media server
    By carol azar in forum Samsung Galaxy Note 3
    Last Post: 12-23-2014, 11:08 AM
  4. s note has started to crash all the time
    By martyn5553 in forum Samsung Galaxy Note 4
    Last Post: 12-23-2014, 08:44 AM
  5. 5.0.1 too many screens
    By mawil1013 in forum Android 5.0 Lollipop
    Last Post: 12-23-2014, 08:38 AM
