1. yo0123yoyo's Avatar
    I love the screen and how vibrant it is on full brightness but when I am near someone and don't want everyone to see what I'm doing on this gigantic screen is when I use auto. Is it normal for the battery to be draining very fast when using full brightness? I'm rooted and using greenify Idk if this should be helping a lot or not lol. Anyways thanks in advance!!
    12-23-2014 02:26 PM
  2. derekfaircloth's Avatar
    I always use max. Yes it drains faster but I have to have it there for optimum viewing pleasure lol
    that's what chargers and xtra batteries are for
    my 2 cents
    John 3:16
    12-23-2014 02:30 PM
  3. sydneycooper1979's Avatar
    Yes on a QHD screen at full brightness, your battery life will most definitely tank!
    12-23-2014 02:32 PM
  4. Almeuit's Avatar
    I can't stand max ... Maybe when watching Netflix or something I go up in the 90s ... but ... Usually I am about 30-40%.
    12-23-2014 02:48 PM
  5. Kevin OQuinn's Avatar
    Yes. Max brightness will drain faster. Display power draw is not as linear as you would think.
    Full brightness will not be twice the power of 50% like you think.
    12-23-2014 02:52 PM
  6. dpham00's Avatar
    Max brightness would drain pretty quickly
    Sent from my Verizon Samsung Galaxy Note 4
    12-23-2014 02:52 PM
  7. naira1's Avatar
    Never had mine in Max brightness. Don't see any need for that. The display is already great and going Max will kill my battery.
    Sent from my SM-N910C using Tapatalk
    12-23-2014 03:19 PM
  8. thetonyclifton's Avatar
    I don't like it above about 50% and usually much lower. It makes the screen brighter not clearer, I think I might be a bit photosensitive as the brighter settings make me uncomfortable
    12-23-2014 03:27 PM
  9. Rarry's Avatar
    I wish there was more offset for the auto setting. I find it too dull even on +5.
    On manual setting around 80% or 90% is good but it's nice to have a phone I don't need to run on 100%.
    The auto boost in sunlight is impressive though it switches back too quickly when shaded. A few more seconds would be useful when trying to check a map or something.
    12-23-2014 04:11 PM
  10. LaTuFu's Avatar
    Yes, of course it is going to drain faster on max brightness.
    In order to notice it, though, you'd need to run your device at a much lower setting for several days to get used to the battery life of the phone at lower settings. That way you'd have a much better frame of reference for the increased rate of drain.
    12-23-2014 04:21 PM
  11. currentdroiduser's Avatar
    You could try power save mode and auto brightness it probably be equal to normal mode with dim
    posted with my note 4
    12-23-2014 05:14 PM
  12. BarfingMonkey's Avatar
    Full brightness in public is obnoxious
    12-23-2014 06:59 PM
  13. FBA's Avatar
    Full brightness is like pedal to the medal in a high performance V8. Gas goes out very quickly!
    12-25-2014 04:27 PM
  1. Is cleaning liquid save to use?
    By Yuna1982 in forum Samsung Galaxy Note 3
    Last Post: 01-12-2015, 11:22 PM
  2. text message box at the top of the screen
    By thenerdjones in forum Samsung Galaxy Note 4
    Last Post: 12-25-2014, 03:51 PM
  3. Portable/External Battery Fast Charging Question
    By Coolboy32 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-23-2014, 10:25 PM
  4. Can Android tablet be used w/o google account?
    By cyclemanstan in forum Ask a Question
    Last Post: 12-23-2014, 08:07 PM
  5. Why does beat sound so sharp?
    By Michael Apn in forum Ask a Question
    Last Post: 12-23-2014, 03:07 PM
