01-02-2015 07:41 AM
58 123
tools
  1. NetNet5's Avatar
    Ease back up will backup contacts if you don't want to use Google contacts. Make sure to copy the backup to the computer before wiping.
    Not sure about whatsapp. I have never used it
    Sent from my Verizon Samsung Galaxy Note 4
    ok thank you very much I really appreciate your help i have a last question just to make sure.
    before few days i turn on the dev options in settings and when i change the scale animation the screen was flickering with red colors for few seconds and then its stops. i dont know if its a little bug or something with the animation i just make sure everything ok.
    It did not happen to me again since it happened to me before 4-5 days but i ask about it just to make sure everything is ok. (btw i cancel the dev options from settings- application manager - all - searcing for "settings" and then click on clear data)
    I found a picture of the problem happened to me just for nexus 5 (the screen was red flickering)
    here is the link,
    finally got my note 4, a few questions-screenshot_2013-06-24-13-32-52_zpseeacecbe.png
    link:
    http://i1071.photobucket.com/albums/...pseeacecbe.png
    again, its never happend me again just once and i just wanna make sure everything its ok beacuse its was so weird.
    thanks so much!!
    12-31-2014 12:48 PM
  2. dpham00's Avatar
    If it doesn't happen again then I won't worry about it
    Sent from my Samsung Galaxy Tab Pro 8.4
    12-31-2014 01:16 PM
  3. calicocat2010's Avatar
    Don't put phone on vibrate it drains battery too.
    12-31-2014 09:55 PM
  4. Jude526's Avatar
    Welcome to Samsung Note4. Love mine. Love the spen. I use it a lot. Am at 43% and it's 8:04 pm. I like bright screen. I use my phone a lot. I don't kind having to charge daily. It lasts all day and that is what matters to me. Fact it charges up quickly is a plus
    12-31-2014 10:07 PM
  5. NetNet5's Avatar
    ok thanks! can you look at the the lists of what i did to save battery if can can tell me more ways i can save the battery life and if what i did is good i will be glad!
    the list is in my next quote.
    vibarate when ringing also? cuz all other vibrate options are off.
    here is all what i did to save battery life longer
    fast charging: on
    brightness - auto -5
    screen rotation - on
    smart stay - on
    screen timeout - 15 seconds
    screen mode - basic
    auto adjust screen tone - on
    daydream - off
    led indictator - on
    touch key light duration - 1.5 seconds
    increate touch senstivity: off
    sounds settings:
    vibrate when ringing: on
    feedback:
    dailing keypad tone: off
    touch sounds: off
    screen lock sound: off
    haptic feedback: off
    sound when tapped: on
    vibrate when ringing: off
    vibrate when tapped: off
    mobile networks: network mode WCDMA/GSM (auto connect)
    wi-fi: advanced settings: always allow scanning: off
    google now: Off
    auto refresh 6 hours on Weather widget
    gmail/email: vibrate off
    bluetooth: off
    sync: on
    accounts - google - sync settings - turned off everything i dont use.
    Smart Stay: off
    NFC: Off
    there is more settings to play with to keep the battery life longer?
    thanks!
    and when you you posts this message its was 10:08 PM so you say after 2hours you with 43% its mean 4-5 hours with heavy use right?
    and i have a question about the home button, sometimes when i click on him he doing some clicking noises. (i dont mean to vibrate/sound from settings its off) i mean noises at the touch of the button itself. Sometimes its sounds like pressure on the button but everything works fine.
    but i heard its normal for all samsung devices.
    what do you say?
    btw which way is the best way to charge the note 4? only when is 10%? 20%?
    thanks everyone!
    01-01-2015 05:21 AM
  6. dpham00's Avatar
    fast charging: on
    smart stay - OFF
    screen mode - basic
    daydream - off
    led indictator - OFF
    sounds settings:
    vibrate when ringing: OFF
    feedback:
    touch sounds: off
    sound when tapped: OFF
    KEEP WIFI ON DURING SLEEP :ONLY WHEN CHARGING
    scanning: off
    google now: Off
    bluetooth: off
    sync: OFF
    Smart Stay: off
    NFC: Off
    thanks!
    what do you say?
    thanks everyone!
    put some suggestions in caps lock
    01-02-2015 01:17 AM
  7. SGN4's Avatar
    agreed
    01-02-2015 05:17 AM
  8. MightyMike's Avatar
    You did very good dpham00. Very good.
    MAY THE 4 BE WITH YOU!
    01-02-2015 07:41 AM
58 123
  1. What does a water damage sticker look like (Samsung Galaxy Note 4)?
    By Clancey123 in forum Samsung Galaxy Note 4
    Last Post: 12-31-2014, 10:15 AM
  2. i cant see front notification in my 360?
    By AKSHAY JAIN8 in forum Moto 360
    Last Post: 12-25-2014, 11:28 AM
  3. restore chat on Galaxy Note 4
    By rumpumpel1 in forum WhatsApp for Android
    Last Post: 12-25-2014, 04:25 AM
  4. Replies: 2
    Last Post: 12-25-2014, 02:28 AM
  5. Replies: 1
    Last Post: 12-25-2014, 02:20 AM
