You can try to see if the battery life is different on 4g vs 3g only , but I guess it would be very minor.
5-6 hours SOT and 12 hours idle in a typical day for me . can go up or down depending on specific usage
Sent from my Verizon Samsung Galaxy Note 4
1. so if i dont have 4g in my area so to put it on 3g only? (WCDMA/GSM) its will be better?
2. And about the sor/idle let me understand something,
SOT = Screen On Time thats i already know buts whats is really means? is playing games/apps/internet/whatsapp and everything else?
and
idle is when im dont use my phone? (Do not use it at allׁׁׂ)
if yes so my SOT is like 5-6 hours and about the idle i checked it while im sleeping i had 100% i woke up after 8-9 hours and the phone was 93% ( i had some voice calls and whatsapp messagesi didnt answer during the night)
if is not what i say so i will glad for explanation.
here is some screen shots from my power saving in settings, i will be glad if someone can tell me if its ok,
power saving:
screen use details:
history deatils: (what is the yellowgreen/gray in the network signal? thats mean i have a bad signal?)
my settings in display are:
fast charging : off (just turned it off to check charging without it, still didnt charge it while it off i will test it soon)
brightness - auto -5
screen rotation - on
smart stay - on
screen timeout - 15 seconds
screen mode - basic
auto adjust screen tone - on
daydream - off
led indictator - on
touch key light duration - 1.5 seconds
increate touch senstivity: off
sounds settings:
vibrate when ringing: on
feedback:
dailing keypad tone: off
touch sounds: off
screen lock sound: off
haptic feedback: off
sound when tapped: on
vibrate when tapped: off
location: off (This is related to the battery? or should i put it on?)
what should i do more?
I will be happy with the recommendations.
3.today i was in the sunlight and the screen was colorful its normal? i heard its beacuse the auto brightness.
and here is a sub question, auto brightness -5 is good for battery or should i put +5 auto or to cancel the auto and put in on the middle? what is the best?
thanks!
