1. ahlong00's Avatar
    Hello people,
    Has anyone notice that their Note 4 camera flash has a warmer tone (like yellowish instead of white) when taking picture under low light or simply using it as a torchlight? Could it be faulty or normal by design?
    12-30-2014 07:24 AM
  2. jeffrey10000's Avatar
    I haven't noticed it on mine. Usually having your white balance wrong will cause yellowing to show up in pictures. I'll try some pictures and see what happens and report back. May need to play around with the white balance.
    12-30-2014 01:39 PM
  3. ahlong00's Avatar
    Thanks in advance! Well, I don't really see any noticeable yellowing on my night photos, just curious that why the flash is yellowish/ warmer as compared to my previous phones which used white led. It is obvious when I just use it as a Torch in the dark.
    12-30-2014 09:19 PM
  4. wgragg's Avatar
    I doubt it is the flash. It is probably the auto white balance which is notoriously inaccurate on almost any camera. Also, if you have a mixture of light temps in a shot, it will really mess things up.
    12-31-2014 02:35 PM
  1. How often do you restart your Note 4?
    By scorpio001 in forum Samsung Galaxy Note 4
    Last Post: 04-27-2015, 09:40 PM
  2. Replies: 1
    Last Post: 12-31-2014, 02:29 AM
  3. Why is my Samsung Note 4 Black screen freezing?
    By Smithy9999 in forum Samsung Galaxy Note 4
    Last Post: 12-31-2014, 02:26 AM
  4. Galaxy Note 4 - Hot screen? Normal heat?
    By earthway22 in forum Samsung Galaxy Note 4
    Last Post: 12-30-2014, 06:55 AM
  5. Replies: 3
    Last Post: 12-30-2014, 12:01 AM
