02-11-2015 08:19 PM
32 12
tools
  1. Kjthomas0724's Avatar
    I am currently using a 32gb Scandisk memory card. I am thinking about switching to a Samsung Evo 64gb. Does anyone have any experience with this card?
    01-02-2015 01:11 PM
  2. sparksd's Avatar
    I have the 128GB Samsung EVO card and don't have any issues with it. The Samsung EVO cards are popular choices for Samsung phones and some people swear they are better than comparable SanDisk cards though I haven't seen that, having using multitudes of SanDisk cards on a number of devices over the years.
    Kjthomas0724 likes this.
    01-02-2015 01:17 PM
  3. LightspeeD00711's Avatar
    yeah, i read that Samsung Evo cards are faster than the same SanDisk ones
    01-30-2015 08:33 AM
  4. M3Stang's Avatar
    I believe mine is that card in which you speak. Everything is great with it.
    01-30-2015 08:50 AM
  5. sbhatia1981's Avatar
    I just changed yesterday to Evo from the Adata ( 64 gb), that's the only one they had in the shop at the time of buying phone.
    I had few problems with Adata card, mainly with media kept draining battery out of sudden then calmed down for few days, heard Samsung card works best so giving it a go, I transferred everything from my old card to Evo and Gave it a while to scan for media and since then it is fine, No media draining battery.
    Hope it stays same, It was already formatted to exfat, i formatted again first on PC and then on phone, then transferred everything over.
    01-30-2015 09:13 AM
  6. D Android's Avatar
    I am using a 64 gb evo one and haven't had one problem, while the previous two Sandisk ones failed miserably within weeks. Stay away from Sandisk all I can say.
    01-30-2015 10:38 AM
  7. M3Stang's Avatar
    A shame. I thought San disc was like the best brand ever.
    01-30-2015 10:56 AM
  8. D Android's Avatar
    Not in my experience. I even complained to Sandisk, they sent me a replacement with no questions asked and that failed too. Will never touch Sandisk ever again. Samsung card I originally had in my S4 is still perfectly fine and I use it a lot.
    01-30-2015 11:10 AM
  9. Kjthomas0724's Avatar
    I put a 64gb evo in my phone this week. Transfered all of my movies, pics, and music to it. At first it kept telling me it couldn't find the movies. Then i got a notification saying rhe card failed and to reformat it. I didn't even get 2 seconds to do anything and it erased all of my stuff that was on it. It was aparently a defective card and I lost most of my stuff.
    Sent from my beautiful white NOTE 4!!
    01-30-2015 11:20 AM
  10. D Android's Avatar
    Where did you get it from? Apparently there a lot of fakes, Samsung is one of the worst at being copied. Like I said earlier I don't have a problem with mine, didn't even have to format it, it was already in exFAT. I just put it in and it worked.
    01-30-2015 11:32 AM
  11. Kjthomas0724's Avatar
    Amazon. I am waiting on a replacement
    01-30-2015 11:40 AM
  12. D Android's Avatar
    If it wasn't from a third party seller on Amazon than it's probably OK, if it was I would be a bit more suspicious. But good luck with the replacement. Let us all know how you get on.
    01-30-2015 11:47 AM
  13. Kjthomas0724's Avatar
    How do you tell if it's a fake??
    01-30-2015 01:17 PM
  14. llfloyd79's Avatar
    I have the Samsung 64GB version and I love it. No issues with it at all.
    Posted via my Samsung GALAXY Note 4
    01-30-2015 01:22 PM
  15. trusigma's Avatar
    I had the same issue with Samsung . Says no files found... Heartbreaking
    01-30-2015 01:36 PM
  16. InVez's Avatar
    Are you talking about the fake Sandisks? I have a Sandisk 128gb without any problem.
    Posted via My Samsung Galaxy Note 4
    01-30-2015 02:52 PM
  17. D Android's Avatar
    No, genuine ones. Maybe they have improved these days but a year or so ago I had no luck with Sandisk.
    01-31-2015 03:50 AM
  18. D Android's Avatar
    Unfortunately it is getting more difficult to tell what is a fake and what is a real thing as the manufacturing of copies is becoming so sophisticated. When I got a fake once from a third party seller on Amazon the packaging was a give away, just did not look right to me and had spelling mistakes. I think the only way to make sure you have a genuine card is to buy it from a reputable source, definitely not on auction sites.
    01-31-2015 04:22 AM
  19. doctordwaynewilliams's Avatar
    I have a purchased a fake in the past. Got it from eBay. Was very disappointed. But should have known that you couldn't buy 128 GB card for under $50. Went to BestBuy and got a legit one and no problems.
    01-31-2015 04:47 AM
  20. Kjthomas0724's Avatar
    If you had to guess, does this look real or fake?????
    Attached Thumbnails Samsung Galaxy Note 4 Samsung Evo 64gb memory card-20150210_122836.jpg   Samsung Galaxy Note 4 Samsung Evo 64gb memory card-20150210_122847.jpg
    02-10-2015 12:30 PM
  21. D Android's Avatar
    If I had to guess, I would say it's fake. The card itself looks more red rather than orange with Samsung's logo on it looking a bit odd. On the back of the packaging on the right hand side where it's printed in grey "micro SDHC" should say "SDXC" if it's 64GB. Also mine says 10 year limited warranty not 5. But of course I could be wrong, I'm sure someone will correct me if I am.
    02-11-2015 06:07 AM
  22. Kjthomas0724's Avatar
    The card is actually orange. When I google the packaging it looks the same as what I am finding online
    02-11-2015 07:22 AM
  23. D Android's Avatar
    The back of this one looks different from yours.
    02-11-2015 07:53 AM
  24. Kjthomas0724's Avatar
    It is a fake. After looking into it more I did determine that it is a fake.
    02-11-2015 08:36 AM
  25. D Android's Avatar
    OK, but I still can't understand why on the back of yours it says SDXC on the left and SDHC on the right and only 5 year warranty. But as long as the card works fine in your phone then that's all that matters.
    02-11-2015 09:28 AM
32 12
  1. I want to buy your Note 10.1 (2012) s pen tips
    By mangurian in forum Samsung Galaxy Note 10.1
    Last Post: 01-19-2015, 04:46 AM
  2. Samsung Galaxy Note 4 hate cases but scared to go naked
    By Lambertoid in forum Samsung Galaxy Note 4
    Last Post: 01-09-2015, 10:45 AM
  3. Organizer app for Note 8 to use S Pen.
    By pinkyxo in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 01-06-2015, 08:36 AM
  4. Replies: 1
    Last Post: 01-02-2015, 10:07 PM
  5. Samsung galaxy note 4 and Imessage issue
    By rycon325 in forum Samsung Galaxy S4
    Last Post: 01-02-2015, 06:54 PM
