Dvoraak
Haven't had this problem with the Note 4 so far but had it consistently with two different S5s. Now I'm worried it's a matter of time for the Note 4.
More likely than not to be an issue of the clock on the CPU going too low. Try increasing the minimum CPU clock speed. Note that this will have a small negative impact on battery life.
Step #1 - Root your phone/device
Step #2 - Install your choice of overclocking app (You're not technically going to be overclocking the device, but yea, you'll need one of these)
Step #3 - Using the overclocking app, set the minimum clock speed one step higher than it already is by default. This should diminish the skipping considerably. If it does diminish the problem, but doesn't solve it to your satisfaction, increase it another step until satisfied. If it doesn't improve the problem at all, then the problem is elsewhere, though unlikely.
This is one of the major reasons why it bothers the hell out of me that carriers try to keep users from changing basic settings on devices that are owned and paid for by their customers. There's absolutely no need for a single person to have to wait for a patch/fix/update for a problem like this. Solving it is extremely easy, albeit impossible for the average user due to greed in the part of people that will make a ton of money either way.
I don't use a screen lock at all and the skipping glitches are happening with my blue tooth.
Got Lollipop installed and it appears this skipping issue is fixed - so far I haven't run into it with the screen off though I haven't run a very long time yet. Can anyone else check this out?
Glad I found this thread because I was really getting pissed off and about returned the LG Tone Pro's I just got. These were the first things I used bluetooth with on my Note, wired never had any issues, but the bluetooth gets these skips like 3-4 times in a song and it's really irritating. The crappier part is my phone is running on Lollipop so the update did nothing for me. I haven't tried any of the other solutions as I just came across this, but I do not have any lockscreen security on my Note. I will try the battery thing and a couple other options to see if it will fix, then resort to a factory reset. If none of these fix this I am going to be deeply disappointed, keeping the screen on seems like an unnecessary option. I feel the blame is solely on Samsung and not Google since this is not a problem with my HTC.
I was able to reduce the frequency of the clipping by switching to the NuPlayer in the developers options but it hasn't completely eliminated them. I even went into safe mode with the WiFi off and I still get clipping, so frustrating. Judging by the amount of complaints on different devices starting with KitKat I'm not sure that we're going to see a fix for this anytime soon. Wish I would have had the chance to try it when I had KitKat on my Note because my buddy who hasn't updated his yet doesn't have this issue.
