1. SteveISU's Avatar
    I picked up the Samsung back to use with my tylt charger. I noticed when the battery his 100% it makes the sound like it's docking and then undocking. Screen also turns on. Is that common? Anyway to stop it from happening?
    01-03-2015 01:04 PM
  2. bertsirkin's Avatar
    I've had the same issue. I use a cheap coil and transmitter I purchased on eBay. I found that depending how the phone is positioned on the transmitter, you can avoid that from happening. My transmitter is rectangular, and I found that I have to place my phone 90 degrees to the transmitter to avoid what you're talking about from happening.
    Try re-positioning your phone in relation to the transmitter.
    01-03-2015 01:39 PM
  3. deepseadiver's Avatar
    I'm using the same but mine doesn't do either one, it works fine. Samsung wireless back and tylt. My note is a Verizon.
    01-03-2015 08:47 PM
  4. harryhoudini66's Avatar
    It may reach 100% and make the sound, then go down to 99% and start charging again and make the sound. Repeat cycle.
    01-04-2015 02:45 AM
  1. Replies: 2
    Last Post: 01-05-2015, 11:31 AM
  2. Replies: 3
    Last Post: 01-04-2015, 12:37 PM
  3. Why is my Galaxy S3 not charging normally?
    By pxgq55a in forum Samsung Galaxy S3
    Last Post: 01-03-2015, 04:02 PM
  4. Replies: 0
    Last Post: 01-03-2015, 04:53 AM
  5. Motorola g will not charge/ turn on??
    By jellywishes in forum Moto G (2013)
    Last Post: 01-02-2015, 04:53 PM
