1. mty msi's Avatar
    My speakerphone worked just fine until a few days ago and now the volume of an incoming call is so low I have to pick the phone up and hold it to my ear. Anyone else having this problem? I'm on AT&T all all the phone's volume settings are at max volume.
    01-08-2015 05:48 PM
  2. B. Diddy's Avatar
    No change after a reboot? Is the volume fine when using the earpiece, or headphones?
    01-08-2015 06:32 PM
  3. mty msi's Avatar
    No change after a reboot. I shut my phone off most nights and reboot in the morning. My Bluetooth earpiece works fine, no loss of volume.
    01-08-2015 06:38 PM
  4. B. Diddy's Avatar
    How about the volume in general when using the main speaker (like when playing music)? Just trying to make sure the problem isn't with the speaker itself.
    01-08-2015 07:11 PM
  5. ohbreeeezy's Avatar
    https://play.google.com/store/apps/d...increasingring
    Try this. Probably not the solution you're looking for tho.
    I use this because I hate how incoming calls starts at a low volume then to high volume.
    01-08-2015 07:13 PM
  6. mty msi's Avatar
    I never play music so I'll have to give it a try.
    01-08-2015 07:31 PM
  7. mty msi's Avatar
    I'm not experiencing any decrease in the ring volume or any of the other audible system notifications, only the callers volume level through the speakerphone.
    01-08-2015 07:33 PM
  8. dpham00's Avatar
    Could be some app that you installed. Have you installed anything recently?
    You can use wear speaker to always use speakerphone at maximum volume
    Sent from my Samsung Galaxy Tab Pro 8.4
    01-09-2015 10:33 AM
  1. Why am I not able to make Bluetooth phone calls?
    By Sachin Kurade in forum General Help and How To
    Last Post: 01-09-2015, 12:58 AM
  2. Replies: 1
    Last Post: 01-08-2015, 03:09 PM
  3. How do I find out unknown numbers on my call log list?
    By Rose5 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-08-2015, 11:00 AM
  4. Why am I unable to make calls when Caller ID is disabled?
    By Clay Greenslade in forum Ask a Question
    Last Post: 01-08-2015, 05:22 AM
  5. My calling won't work!
    By anniebrwn in forum Samsung Galaxy S4
    Last Post: 01-08-2015, 02:05 AM
