a weird problem about the sound and more questions
Hey Guys,
I have some questions I'd be happy if you answer them.
1. A few minutes ago i had a very strange problem thats already happened once before less than month.
the problem is my sound suddenly disappeared! cant hear nothing no music, messages, apps/games and nothing.. the note is on "sound" option no vibrate or mute and all the sound settings on, its happend me before like i said before a month. how i fixed it? by normal restart and everything back to normal.
what should i do?
2. I have the note 4 just over a month and i happy so much after alot of years with an iPhone and i have one weird question about the home button, sometimes when i click on the home button he makes some noises. i do not mean about noises from settings i mean clicking noises.
the noises comes mostly when i click on the center of the button, when i click on the left/right side of the button there is no clicking noises. thats normal?
3. my last question is about the battery life,
from 100% to 10-0% while im using apps/calls/whatsapp/youtube videos and more its like 6-7 hours its ok? (sometime less) i checked and during night with wi-fi on from 100% the battery drops to 93% like 7-8 hours.
the question if its a good battery life?
this is what i did with the settings to try to save my battery life, if you got more settings to do/change i will glad to hear about them.
thank you very much.
have a great day!
Hey Guys,
what should i do?
fast charging: off
brightness - auto -5
screen rotation - on
smart stay - OFF
screen timeout - 15 seconds
screen mode - basic
auto adjust screen tone - on
daydream - off
led indictator - OFF
touch key light duration - 1.5 seconds
increate touch senstivity: off
sounds settings:
vibrate when ringing: OFF
feedback:
dailing keypad tone: off
touch sounds: off
screen lock sound: off
haptic feedback: off
sound when tapped: OFF
vibrate when ringing: off
vibrate when tapped: off
mobile networks: network mode WCDMA/GSM (auto connect)
wi-fi: advanced settings: always allow
KEEP WIFI ON DURING SLEEP :ONLY WHEN CHARGING
scanning: off
google now: Off
auto refresh 6 hours on Weather widget
gmail/email: vibrate off
bluetooth: off
sync: OFF
accounts - google - sync settings - turned off everything i dont use.
Smart Stay: off
NFC: Off
have a great day!
