1. bat0nas's Avatar
    How „Smart network switch” actually work?
    Does it measure the download speed or signal strenght? Because switching between networks without that enabled also works.
    Sent from my mobile device
    01-19-2015 12:02 AM
  2. Rukbat's Avatar
    If your connection gets a bit weak, and there's a stronger signal available, it switches. Switching between IP addresses (which will happen if you switch between mobile data and wifi - in either direction) will break the connection, so if you're downloading a file when it happens, you'll have to start over. (It's fine for web browsing, because browsers operate in disconnected mode. They get the page, then disconnect. So if the next request is for a link to another page on that site, and it comes from another address, the site doesn't care.)
    It doesn't care if the signal you're using gets weak for a fraction of a second (which internet apps can handle), it switches.
    The phone normally works better with it disabled.
    01-19-2015 12:24 AM
  3. bat0nas's Avatar
    Thanks. I enabled it just to test. Interesting what impact it will have on my daily activities and battery life.
    01-19-2015 01:22 AM
  1. How can I print from a galaxy s4 to an Epson WF-2540 printer?
    Last Post: 04-09-2016, 09:51 PM
  2. Replies: 2
    Last Post: 01-28-2015, 09:55 PM
  3. Replies: 2
    Last Post: 01-19-2015, 06:09 AM
  4. Replies: 1
    Last Post: 01-19-2015, 01:12 AM
  5. How can I recover my cellphone from a bootloop/white screen error?
    By SaIm JoHn PaUl in forum Ask a Question
    Last Post: 01-19-2015, 12:41 AM
