1. cbeattie411's Avatar
    I got my verizon note 4 on release withing the last month it's really started to cap out. It seems to be lagging like crazy, freezing up a couple times a day, missing app icons and of course the alarm clock update drives me crazy. On a good note, my battery life is still phenomenal. Anyone else having issues.
    01-20-2015 07:33 PM
  2. russel5150's Avatar
    I would check any recent apps you have downloaded, esp one that uses the stock clock app, because ive never seen an update for that.
    Clearing the cache partition is a good place to start if you dont see any rogue apps, after that a factory data reset.
    Someone else on here will have better and more detailed advice, but its a starting point
    Golfdriver97 likes this.
    01-20-2015 08:15 PM
  3. jwt873's Avatar
    I found that using the Firefox browser will sometimes drag down the phone and make it run very slowly. (This never happened with my Note II). I've started using the Chrome browser. It doesn't cause any problems.
    01-21-2015 08:14 AM
  4. Craig Lawson's Avatar
    No problems or lags on mine
    There are a few things you can do..
    Change to . 5 or Off
    turn off svoice on home button
    01-21-2015 09:46 AM
  1. My Galaxy Note Edge battery is not charging, what do I do?
    Last Post: 08-24-2015, 10:03 AM
  2. Replies: 1
    Last Post: 01-21-2015, 12:55 AM
  3. Why are all of my calls on Turbo going to voice mail?
    Last Post: 01-21-2015, 12:54 AM
  4. Can I skip the activation on my Samsung Galaxy S5 Verizon?
    Last Post: 01-20-2015, 07:35 PM
  5. Replies: 0
    Last Post: 01-20-2015, 07:17 PM
