1. Hotswopp's Avatar
    Randomly through the day, my phone makes the puddle/water drop sound. If i am quick and look at the screen the OneDrive app info screen is up. this happens even when the phone is locked. it lasts about 2-3 seconds and then goes away. I don't know what it is doing, but it is annoying. There doesn't seem to be any settings for this type of behavior. Just wondering if anyone else has seen anything like this?
    01-22-2015 08:59 AM
  2. Bosbouer's Avatar
    It is syncing with one drive. Have a look in the one drive app settings to turn off its Notifications or disable its auto sync
    01-22-2015 10:18 AM
  3. SpookDroid's Avatar
    Is it always the OneDrive screen? If so, have you tried 'freezing' the OneDrive app for a while and see if it stops? You might not be able to freeze the app but only uninstall it, but that's also worth a try... I mean, all you'd have to set up again are settings, everything else is in the cloud, right?
    UPDATE: Apparently the post above me has a solution, so my suggestion is probably pointless now hehe
    01-22-2015 10:21 AM
  1. Replies: 2
    Last Post: 05-09-2015, 11:24 PM
  2. Replies: 1
    Last Post: 01-22-2015, 01:06 PM
  3. Replies: 1
    Last Post: 01-22-2015, 09:08 AM
  4. How can I root my Samsung Galaxy Tab 3 for 10.1?
    Last Post: 01-22-2015, 08:55 AM
  5. Can I get some help with my S3?
    Last Post: 01-22-2015, 08:20 AM
