1. FireFab's Avatar
    Hi ! I got a Galaxy note 4 with Otterbox defender I think (The one with the screen protection 2 layer with the belt clip)
    I want to know what's the best car mount for this phone with the case on.
    Thanks !
    01-22-2015 12:44 PM
  2. tsells's Avatar
    Thanks !
    The ProClip is the best mounting system for any car. It's expensive, but really worth it. You need to order the car holder (which is made specifically for each make/model), and you need a phone holder. I have a case on my Note 4 (but not an Otterbox), and it works great. For the Otterbox, you'll probably need the largest of the universal phone holders.
    EDIT: I just checked on ProClip site and they have a mount speciafically for the Note 4 with an Otterbox Defender:
    http://www.proclipusa.com/phone-hold..._leftorright=0
    The above is just the holder. You then have to get the proper car mount. As I said, this is an expensive solution but one that I have been using for many years because it's the best and most secure car mount that I have ever used.
    01-22-2015 01:07 PM
  3. beh's Avatar
    This iBolt mount is a very well liked cell phone mount for vehicles. I have one and 2 prior versions over the years and have nothing but "good" to say about the product. This mount should hold your phone and otterbox and a quick contact to the company should confirm. I only use by Note's naked so don't have first hand knowledge.
    Amazon.com: iBOLT xProDock Connect Kit Universal Car Holder: Cell Phones & Accessories
    01-22-2015 02:37 PM
  4. pmccartney's Avatar
    The Scosche MagicMOUNT is great for me. Holds my Note 4 and Z30 easily and on any angle. Never had a problem with them. My Note 4 has a Seidio Surface case on it too.
    shaleem likes this.
    01-22-2015 02:58 PM
  1. Replies: 1
    Last Post: 01-22-2015, 12:51 PM
  2. Replies: 1
    Last Post: 01-22-2015, 12:34 PM
  3. MY samsung galaxy k zoom is going straight to answerphonef
    Last Post: 01-22-2015, 12:11 PM
