1. Andrews sawiri's Avatar
    I drop my galaxy note 4 phone in the snow this morning, I have already taken out the batt and the SIM card, the post i am reading from this forum advice me to put it in rice, please, is it the raw rice or cooked?, the whole phone or just the batt?
    Please, help if you can.
    Thanks.
    01-24-2015 10:01 AM
  2. palandri's Avatar
    Raw rice
    01-24-2015 10:10 AM
  3. ScottsoNJ's Avatar
    Thanks.
    They sell a kit for phones dropped in water. Probably at Best Buy
    01-24-2015 10:11 AM
  4. Golfdriver97's Avatar
    01-24-2015 10:12 AM
  5. Andrews sawiri's Avatar
    Thanks, will check it out.
    01-24-2015 10:59 AM
  6. z06mike's Avatar
    If it was just snow and it was a quick drop I'm sure your phone is ok!
    01-24-2015 11:05 AM
  1. Replies: 3
    Last Post: 02-05-2015, 08:28 PM
  2. Can i use all micro sd type cards in the galaxy tab s 10.5?
    Last Post: 01-25-2015, 02:28 AM
  3. What phone number do I put for code to install?
    Last Post: 01-24-2015, 10:09 AM
  4. Replies: 2
    Last Post: 01-24-2015, 10:00 AM
  5. Replies: 0
    Last Post: 01-24-2015, 09:06 AM
