1. George Hora's Avatar
    Hello ! I bought my Samsung Note 4 in December , no problems since yesterday while speaking with my father , he told me that he can't hear me , all he can hear is a sound like the sound you hear when you are standing near a speaker with your phone . When i move the call to SPEAKER the sound dissapears , it's super clear like it should be , when i move it back to NORMAL CALL the sound comes back as soon as i push the button . ( sorry for my bad english , it's not my first language )
    Thank you for your help !
    01-27-2015 12:13 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It sounds like a problem with the phone mic. Make sure there isn't any debris (like lint) stuck in the microphone. If it looks clean, the microphone might be faulty. You'd have to bring it back to the store, or contact Samsung.
    George Hora likes this.
    01-28-2015 12:08 AM
  3. George Hora's Avatar
    I tried to clean the mics , very gentily , now you can hear something but the sound is very low now . You need to speak very loud so you can hear something . Both microphones look clean inside . The problem is I don't have a warranty because of some issues with the store and i don't want to take it to a service .
    01-29-2015 09:50 AM
  4. B. Diddy's Avatar
    If there is some debris or residue packed into the microphone opening, it might be hard to clean out on your own without risking damage to the mic. You could bring it to a local repair shop and ask them how much they would charge to clean the area out. I can't imagine that it would cost much.
    01-29-2015 12:11 PM
  5. George Hora's Avatar
    It's not about how much would it cost , but i'm scared they will damage the device or replacing parts . I usually do not trust the repair shops because they don't give you any warranty . Plus i just moved out from my country and i don't speak the language very good , so it will be hard to explain what it's relly happening with it .
    01-29-2015 12:25 PM
  6. B. Diddy's Avatar
    The best I can suggest is to use a brush with fine rigid bristles and spend some more time gently cleaning out the microphone openings. You might be able to get more stuff out.
    01-29-2015 04:03 PM
  7. George Masina's Avatar
    I had issue with no sound with my Note 4 including internal and external speaker and the mic. Factory reset didn't help. It was in a case so i know it wasnt dirt or debris. What did help was turning off the phone removing the battery SD card and Sim card. Put it all back together and it worked like new. Not sure why it worked but I read in one of the blogs...hope that helps.
    04-05-2015 10:03 PM
  8. russel5150's Avatar
    If its under warranty they should replace it.
    My mom had the internal speaker mess up on her note 3, doing pretty much the same thing.
    If you are by chance using the hd calling, tuen it off and see if that fixes it
    04-05-2015 10:44 PM
  1. How do I solve wifi problems on samsung galaxy ace 2?
    Last Post: 02-13-2015, 01:19 AM
  2. Where is the delete button for Gmail on my Hudl1?
    Last Post: 01-28-2015, 01:11 AM
  3. Replies: 1
    Last Post: 01-28-2015, 12:13 AM
  4. Sync profile photo from gmail to Samsung Galaxy S5?
    By atomarchio in forum Samsung Galaxy S5
    Last Post: 01-27-2015, 11:57 AM
  5. My Samsung Galaxy S4 got wet, is it savable?
    Last Post: 01-27-2015, 11:50 AM
