1. mastercraftx235's Avatar
    I purchased a Developers Edition thinking I would have the ability to edit the APN settings on the Note 4. The Verizon version doesn't allow editing and apparently neither does the Developers Edition!! I use a local regional carrier and everything works except MMS. I have the APN setting.
    01-29-2015 12:12 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! So you can see the APN section in the settings, but you can't edit them? What happens when you tap on the APN? Or are you unable to even see the APNs? Can you add a new one?
    Show us a screenshot of the APN screen. http://forums.androidcentral.com/amb...d-central.html
    01-29-2015 01:56 PM
  3. mastercraftx235's Avatar
    I can see APN settings. Only one setting listed - cannot edit, cannot add new.
    02-02-2015 06:58 PM
  4. dpham00's Avatar
    Did you put in the non verizon sim?
    Sent from my Verizon Samsung Galaxy Note 4
    02-02-2015 07:03 PM
  5. Phoenix111's Avatar
    You have to have a non Verizon Sim for the Developer Edition?
    Sent from my SM-N900V using Xparent Green Tapatalk 2
    02-03-2015 06:26 PM
  6. dpham00's Avatar
    Yes you can have a non verizon sim in a developer edition
    Phoenix111 likes this.
    02-03-2015 06:29 PM
  7. Phoenix111's Avatar
    Ok, but it's not mandatory right? I mean, couldn't I just flip in my Note 3 Sim?
    02-03-2015 06:31 PM
  8. dpham00's Avatar
    Yes you can use your note 3 sim too
    02-03-2015 11:17 PM
  9. mastercraftx235's Avatar
    Default
    I put in a Tmobile SIM and was able to add a new APN. When I put the other carrier's SIM back in (Bluegrass Cellular) the new APN setting was removed. This is the Develpor Edition and I have Root, but I don't know what I need to do to edit. I am extremely comfortable working with PC's, operating systems, etc. but I would be new to installing a custom ROM - is that the only answer?
    Apparently Bluegrass Cellular uses Verizon for their roaming.
    03-06-2015 04:03 PM
  1. Note 4 - OS Update - Canada
    By jeffiekins in forum Samsung Galaxy Note 4
    Last Post: 07-09-2015, 09:35 AM
  2. Note Edge dropping calls during every phone call! anyone else?
    By MrToneBoneZ in forum Samsung Galaxy Note Edge
    Last Post: 06-19-2015, 01:05 PM
  3. Note 4 wireless charging back
    By KoukiFC3S in forum VR Headsets
    Last Post: 03-01-2015, 06:25 PM
