1. 420benz's Avatar
    Would like to see that info on the home page. As in photo at top ( wifi,mail etc.
    Attached Thumbnails How to get the top info in the photo on home page-1422828421422.jpg
    02-01-2015 04:07 PM
  2. Rukbat's Avatar
    Those are all different data put there by different apps or parts of Android. There are apps that will give you widgets for some of them, badges to show you if you have emails or missed phone calls, etc. The actual "picture" of the notification bar? I don't think you can do that unless you write your own app to do it.
    02-01-2015 04:18 PM
  3. MalinoisK9's Avatar
    You have it turned off in Nova. Go to look and feel and check show notification bar. You can set a gesture also to toggle the notification bar like swipe up or double tap on the screen.
    02-01-2015 06:59 PM
  4. 420benz's Avatar
    Thanks for the info.
    02-01-2015 08:56 PM
  5. 420benz's Avatar
    Malinoisk9: That was the problem. Thanks.
    02-02-2015 08:43 AM
  6. 420benz's Avatar
    Well it worked for a short time and it dissapered again. I need to click the notification tab every day. Don't know what is causing this problem.
    02-10-2015 04:10 PM
  7. 420benz's Avatar
    What should I do now.
    Thanks
    02-11-2015 07:37 AM
  8. Bosbouer's Avatar
    I recall a setting in Nova to "lock" the screen settings. Did you use that as well?
    02-11-2015 07:46 AM
  9. 420benz's Avatar
    No. But I will. Thanks
    02-11-2015 04:01 PM
  1. How to link Facebook contacts with contacts.
    By kami8586 in forum Samsung Galaxy Note 4
    Last Post: 10-23-2015, 06:03 AM
  2. Attaching a picture to a text.
    Last Post: 02-01-2015, 08:39 PM
  3. Why couldn't I answer a call on LG Optimus L2II E435k?
    Last Post: 02-01-2015, 08:29 PM
  4. How to copy messages on to a memory card on s3?
    By m_maslarevic in forum Ask a Question
    Last Post: 02-01-2015, 08:26 PM
  5. how can i boost volume for rooted galaxy mega 6.3 I9200
    By Kenny Giles in forum Samsung Galaxy Mega 6.3
    Last Post: 02-01-2015, 04:23 PM
