1. naughtydog's Avatar
    Hi all, my uk unlocked note 4's battery was horrible today and didnt wven last till i got home. Im not a heavy user so i couldnt understand it. Anyway i checked and its android os and android system that used 50% of my battery..... WTF why has this just started happening. Thanks, Matt.
    02-02-2015 03:35 PM
  2. Android D's Avatar
    did that once to me...it was overnight and my battery drained like crazy...All i did was a simple reboot and that fixed it for me.
    Try that if u haven't already
    02-02-2015 03:40 PM
  3. Ntchwaidumela's Avatar
    Were you connected via wifi or your network? You can use a lot of battery if the device is constantly searching for signal. You might try clearing your cache, too.
    02-02-2015 03:44 PM
  4. naughtydog's Avatar
    Thanks for replying, ive been on mobile network all day but the signal has been good qith 0% loss of signal. I have cleared the cache and rebooted the handset, will see haow i get on tomorrow. Once again thanks for the replys.
    02-02-2015 03:50 PM
  5. Almeuit's Avatar
    Can you show us the stats via screenshots?
    02-02-2015 06:36 PM
  6. joklun's Avatar
    It seems like the problem I'm having. All of the sudden my phone refuses to go into deep sleep when it's idling. It gets stuck at 300mhz for some reason (I checked it with the app "cpu spy") which drains the battery. Android OS gets pretty high when this happen. A reboot fixes it but then after some days the same thing happens again. I don't know why this happen. It started for about 2 weeks ago, before that it has never happened. Can it be the same problem?
    02-03-2015 10:20 AM
  7. naughtydog's Avatar
    Thanks guys it seems to have sorted itself out, i cleared cache and rebooted before i went to bed last night. Left for work at 5am this morning and 14 hours later still have 75% light use only tho. Happy with that ☺
    02-03-2015 02:42 PM
  1. S5 Battery Draining Fast, Seriously Hot, and Slow
    By rkatz94 in forum Samsung Galaxy S5
    Last Post: 04-14-2015, 02:24 AM
  2. Replies: 1
    Last Post: 02-03-2015, 01:40 PM
  3. Replies: 2
    Last Post: 02-02-2015, 08:28 PM
  4. Why is my Galaxy S5 battery draining so quickly?
    Last Post: 02-02-2015, 04:10 PM
  5. External Battery Pack & Charger
    By randun in forum AT&T Samsung Galaxy S4
    Last Post: 02-02-2015, 12:36 PM
