1. currentdroiduser's Avatar
    I can't figure it out
    posted with my note 4
    02-03-2015 05:25 PM
  2. z06mike's Avatar
    Go to menu>settings>sound and under ringtones and notifications, you can set whatever you'd like as your ring and text notification.
    02-03-2015 05:41 PM
  3. GregMargie's Avatar
    I think I know what the OP is trying to convey, as I too sometimes will set a ringtone separately for "email" and a different one for "text message" but the same tone ends up playing for both notifications.
    02-03-2015 06:04 PM
  4. currentdroiduser's Avatar
    Correct
    02-04-2015 03:02 PM
  5. GregMargie's Avatar
    Correct
    Ya, I haven't completely solved this either. It seems that certain Apps (within the app) will let you set a specific notification sound and others just fall under the 'default' notification sound that was set in general settings. For example, Under general settings > sound > notifications, I have ringtone set as "Fairydust". In my Specific texting app; Textra I have set Pure Bell as the tone, but when I get a text message from someone it rings as "Fairydust that is set in the general notifications setting. So now when I hear it, I think I received a text, but it was actually an email! I have different ones set for Gmail and Cox Email (I keep them separate on my phone) and those do play the different tones.
    So unfortunately, I think the Tone set under the General settings overrides some, but not all others....at least this is what I am finding to be the case on my phone.
    02-04-2015 03:59 PM
  6. lsmachado's Avatar
    If you are using the stock messaging app:
    Open the messaging app as though you are going to send a text > tap the 3 vertical dots in the upper right corner > tap Settings > scroll down the list to "Notifications" > tap the slider bar in the upper right corner to select "On" > tap "Notification Sound" > select your desired sound > tap "Done" at the bottom of the page once you have selected your sound. If you don't select "Done", the sound won't be saved.
    Hope this helps. I'm on at&t btw.
    Posted via the Android Central App on my bodaciously awesome Note 4!
    02-05-2015 11:06 AM
  7. GregMargie's Avatar
    Thank you for your input! I actually don't use the the stock app, but Textra works the same way, and I do have the tone set up exactly as you have described and Saved (Done)
    02-05-2015 01:02 PM
  1. How can I find out what network my phone is locked to?
    By jax1234 in forum Samsung Galaxy S5
    Last Post: 05-17-2018, 03:13 AM
  2. How do I change the colors on my S5?
    By daleoran in forum Samsung Galaxy S5
    Last Post: 02-03-2015, 06:03 PM
  3. How to Restore Android 5.0.1 (Stock) to my Nexus 5.0.1?
    By Marc Soda in forum Google Nexus 6
    Last Post: 02-03-2015, 05:53 PM
  4. How do I change the default install location on my Galaxy S4?
    Last Post: 02-03-2015, 05:51 PM
  5. How to Restore Android 5.0.1 (Stock) to my Nexus 5.0.1?
    Last Post: 02-03-2015, 05:50 PM
