1. LightspeeD00711's Avatar
    I love the Note 4. Sure it could be better. Like front speakers, less TouchWiz and maybe a lil' thinner. That would make it 2014's best phone for sure. Hands down! One thing i noticed is when i'm in a call, i cant hear the other person loudly, even with full volume. (Not using the back loud speaker) I notice that other phones i used are louder. Anyone else feel the same? (or is it just my phone?) It's not very soft, just i wish it was a bit louder. I always turn on the back speaker because of that. Hope anyone out there can give me feedback on it. How is chatting on ur own Note's ?
    02-05-2015 03:57 AM
  2. plumcrazy's Avatar
    no issues here at all
    02-05-2015 06:08 AM
  3. adegbenroagoro's Avatar
    I've not had any such problem.
    02-05-2015 03:13 PM
  4. Amb312's Avatar
    No issues here. I usually turn mine down because people are too loud.
    Tatt2014 likes this.
    02-05-2015 03:17 PM
  5. magichoward's Avatar
    When you are on a normal call you can press the small green circle that comes up toward the top right of the phone and it increases the volume beyond the norm.
    Also you can change the pitch of the calls in call settings.
    Hope that helps
    Posted via the Android Central App. Magichoward
    02-06-2015 04:52 AM
  6. russel5150's Avatar
    Mine is nice and loud. I actually like that the volumes are much higher than on the previous notes.
    I had been spoiled to the volume levels on the Droid maxx, the note 4 gets close
    Verizon Note4 w/ Tech 21 case
    02-06-2015 10:26 AM
  7. Tatt2014's Avatar
    I always thought the call volume was just fine on my phone,but now i just tried that and wow what a difference!! Thanks a million for that great tip !! I never knew about that setting
    02-07-2015 08:34 AM
  8. Mr-Guy's Avatar
    There's no front speaker on the Note 4
    02-07-2015 09:25 AM
  1. 5.0 update on sprint
    By whoknows00100 in forum Samsung Galaxy S5
    Last Post: 03-16-2015, 04:13 PM
  2. Replies: 1
    Last Post: 02-05-2015, 12:51 PM
  3. Why can't I send pics on my Android Moto G 4.4 version?
    Last Post: 02-05-2015, 07:02 AM
  4. How to sync outlook calender to S-planner on S5?
    By Eric Lau in forum General Help and How To
    Last Post: 02-05-2015, 03:30 AM
  5. Huawei Y511, Boardtest fail, What should I do ?
    Last Post: 02-05-2015, 03:15 AM
