1. bhikumatre's Avatar
    Has anyone experienced sudden battery drain on Note 4. The battery was at 70% around 10:30pm. When I checked next morning (8am), The phone was dead. This is the first time it occurred.
    02-05-2015 09:13 AM
  2. Closingracer's Avatar
    My phone has its own battery drain issues but never this bad. I suggest a clean refresh of your phone which I am considering doing
    bhikumatre likes this.
    02-05-2015 09:14 AM
  3. russel5150's Avatar
    More than likely an app went rogue or something didnt shut off like it was supposed to.
    First steps is check any new apps tou might have, and its alway a good idea to do a cache partition clear.. theres instructions on that n the forums.
    If you checking apps and want to know what caused it, dont change anything yet, charge the phone and then keep a check on it and if there is a fast drain check your batt usage and see whats killing it.
    Another option is if your carrier was down for a while and had a weak or no signal your battery drained trying to connect to a network.. that happens..
    Verizon Note4 w/ Tech 21 case
    02-05-2015 09:18 AM
  4. Almeuit's Avatar
    I haven't. What do your battery stats show ?
    02-05-2015 10:31 AM
  5. bhikumatre's Avatar
    How do I check Battery stats?
    02-05-2015 10:49 AM
  6. russel5150's Avatar
    Go to settings and then battery, it will tell you how long youve been off the charger, and under that it will break down battery usage by percents.. usually tour screen uses most if you have been active on the phone w the screen on. Just look and see if there is something that you havent used much taking a large percent.
    Keep in mind system UI and such will take some because that's the "computer" part of the phone thats always running when the phone is turned on.
    Look and see whats using the most power, and if u can screen shot the list and post it on here thats always helpful for the people on here who are a lot smarter than me lol
    02-05-2015 11:04 AM
  7. joklun's Avatar
    Have you checked these two threads
    http://forum.xda-developers.com/note...1#post58503111
    and
    http://forums.androidcentral.com/sho...d.php?t=487717
    Seems like similar problems (I started one of the threads )
    02-05-2015 11:07 AM
  8. toshee2000's Avatar
    The same thing happened to me last night. There were no apps running that time and I was asleep. Just look at the battery drain..Has anyone experienced a sudden battery drain on the Note 4?-screenshot_2015-03-06-07-27-37.jpg
    03-05-2015 05:35 PM
  9. Bibi200's Avatar
    Hey, toshee2000, have you found out anything? I'm having the same issue. It happens every night.
    The stats show the battery starts draining at 6pm and goes down till 12pm.
    03-08-2015 03:12 PM
  10. dakota316's Avatar
    My biggest thing I found draining my battery, I would get home from work with 40% or so left on my phone working 5 AM - 3 PM and not using it much. I removed Nova Launcher and went back to stock as its so much smoother than before now on Lillipop.... now it is 7:17 PM and I am still at 68%. No change in usage, etc.
    03-08-2015 07:17 PM
  11. tivoboy's Avatar
    Since upgrading to lollipop my battery drains about 50% faster. I used to get 2-3 days battery life, now I get about 18 hours max.. it's a real bummer for what was a superb device.
    03-10-2015 08:45 AM
  12. mlbyanks11's Avatar
    Mine is terrible I barely even used it since I woke up and it just drains...I hate it... Don't even tell me it's the battery it's brand new...
    Attached Thumbnails Has anyone experienced a sudden battery drain on the Note 4?-screenshot_2015-03-10-11-19-55.jpg   Has anyone experienced a sudden battery drain on the Note 4?-screenshot_2015-03-10-11-20-00.jpg
    03-10-2015 10:21 AM
  13. lapk78's Avatar
    I feel like a total noob here, but I can't find "battery" when I'm in "settings." Not by swiping down in the notification bar and tapping the little gear, nor by entering "settings" via the app drawer. Why am I dumb and what am I doing wrong?
    Also, since the Sprint Lollipop update, my battery has definitely taken a hit. Wiping the cache hasn't really helped. Grumble...
    03-10-2015 11:34 AM
  14. PookiePrancer's Avatar
    I thought my upgrade to lollipop was flawless, but I started feeling like my battery was draining a bit fast. I uninstalled the last few apps I got before the update, but it didn't help. Then I noticed fast charging wasn't working right either, so I knew something was up. Resorted to just doing a factory reset, and reloading all my apps, and everything is peachy again.
    Tatt2014 likes this.
    03-10-2015 11:51 AM
  15. tivoboy's Avatar
    If you are having issues with battery, maybe try what I did. It really worked.
    Start at about post #80
    http://forums.androidcentral.com/sam...omments-4.html
    03-12-2015 08:39 AM
  16. lapk78's Avatar
    Bump.
    Help, I can't seem to be able to view my battery usage stats. Any help would be appreciated.
    03-13-2015 11:28 AM
  17. tivoboy's Avatar
    There is no "battery" setting area per se, it's in settings under SYSTEM and it's in the POWER SAVING area?
    03-13-2015 11:47 AM
  18. lapk78's Avatar
    Ahh, there it is. Thanks so much.
    03-15-2015 01:11 AM
  19. ronpfid's Avatar
    I just had this, and saw it happen, battery was at 85%, I opened voice recorder, phone immediately shut down, held power button to turn on, said battery critically low 0% and shut back off. Weird!
    05-21-2016 10:54 AM
  20. NexusGirlX's Avatar
    Yours sounds like it's the battery.
    My original two batteries are starting to do this when the battery gets down to about 10%. Sometimes if I open an app, it will drop down to as much as 3% instantly. My batteries are about 15 months old now. I bought two new batteries but I'm going to keep using the originals until I start having major drainage problems.
    05-21-2016 12:40 PM
  21. kpdx's Avatar
    Yes I have. A new battery solved the problem. Think it was a dendrite from the fast charging
    05-22-2016 11:14 AM
  1. Replies: 1
    Last Post: 02-05-2015, 11:54 AM
  2. Why won't my S5 phone charge?
    Last Post: 02-05-2015, 11:19 AM
  3. Replies: 3
    Last Post: 02-05-2015, 11:10 AM
  4. What's 'broke', the battery or the lead?
    Last Post: 02-05-2015, 08:13 AM
  5. Replies: 0
    Last Post: 02-05-2015, 05:01 AM
