1. Kjthomas0724's Avatar
    Clean Master speed booster or battery doctor? Just wondering if anyone uses either and if they actually make a difference
    Sent from my beautiful white NOTE 4!!
    02-05-2015 01:02 PM
  2. sloppygti's Avatar
    No point IMO. your phone does what it needs to do to take care of managing its ram and what not. You can kill the recent apps and it will stop most apps running in your background.
    Think to your self would you use clean my PC or any of those so claimed scan your computer commercials?
    iOSConvert2k14 likes this.
    02-05-2015 01:12 PM
  3. Kjthomas0724's Avatar
    I had them both on my s4 before I got my note 4. When I got my note 4 I downloaded them I guess out of habit. Im not sure how much they actually help and was already thinking about deleting them.
    02-05-2015 01:24 PM
  4. Smply_Rckless's Avatar
    I used clean master only to rid of cache temp files. No use in it other than that imo.
    Tapatalk'n On The IPhone 6+
    02-05-2015 01:25 PM
  5. Kjthomas0724's Avatar
    That was all I really used it for. So I decided to just delete it
    02-05-2015 01:54 PM
  6. shaleem's Avatar
    Tried Clean Master for awhile, but saw no point in keeping it.
    02-05-2015 02:38 PM
  7. Racinghart91's Avatar
    I use greenify donation so I can shut down stock apps like Facebook. And Imo it works well with battery life. But i can be imaging
    02-05-2015 04:20 PM
  8. felloffthetruck's Avatar
    Clean Master is so full of ads and crap, I uninstalled it 5 minutes after installing it. Garbage
    Bosbouer, Tatt2014 and sforsyth01 like this.
    02-05-2015 04:25 PM
  9. Thirst91's Avatar
    Android now days is pretty good at doing all of that on its own. I think it's just a waste memory
    Tatt2014 likes this.
    02-05-2015 05:48 PM
  10. iOSConvert2k14's Avatar
    I used to use clean master but uninstalled it. No point in it really because android manages ram much more efficiently than iPhones
    02-05-2015 11:09 PM
  11. ansa82's Avatar
    I use shut app. Easy to use and it works
    Donald Smouse1 likes this.
    02-06-2015 08:29 AM
  12. Tatt2014's Avatar
    I did the same thing,i had it on my s4 and then put it on my Note 4,but uninstalled it because i think it is a waste of memory! I can't see what it really does to help
    02-06-2015 09:54 AM
  1. Replies: 4
    Last Post: 07-06-2015, 04:32 PM
  2. Is there a way to enhance the S5 for use with hearing aids?
    Last Post: 02-05-2015, 11:22 AM
  3. How do I use internal memory for storing files?
    Last Post: 02-05-2015, 10:50 AM
  4. How does one use the TTY function on a HTC One M-7?
    By Goldfinger321 in forum HTC One M7
    Last Post: 02-05-2015, 10:40 AM
  5. Why does wireless charger only charge to 70?
    Last Post: 02-05-2015, 10:32 AM
