11-29-2017 11:07 PM
173 ... 34567
tools
  1. donebrasko's Avatar
    Mine has been horrible since I did this. How do we fix it?
    Attached Thumbnails If battery issue, delete cache, fixed my battery issue-1435023799062.jpg   If battery issue, delete cache, fixed my battery issue-1435023811572.jpg   If battery issue, delete cache, fixed my battery issue-1435023830134.jpg
    tonyr6 likes this.
    06-22-2015 09:43 PM
  2. Kelly Kearns's Avatar
    Yours has been horrible since you did what exactly?
    06-30-2015 06:54 PM
  3. donebrasko's Avatar
    Since I cleared the cache
    06-30-2015 08:45 PM
  4. Kelly Kearns's Avatar
    There is nothing about clearing cache that would make you have horrible battery. It looks like Android OS is running a lot and that could be many things.
    06-30-2015 08:50 PM
  5. donebrasko's Avatar
    I just know I didn't have a problem until I did that.
    07-01-2015 12:24 AM
  6. jeremmar's Avatar
    I have had the same problem.. My battery is taking a hit after doing this process to clear the cache. Not sure what to do about it....
    07-01-2015 12:31 PM
  7. Javier P's Avatar
    Clearing the cache could have fixed a problem that was causing the battery drain. The thing is, all that cached data must be created again. Your apps will take a little longer to load the first time and in general your battery will take a hit, but that's temporary. It can't be considered as a battery drain. If your battery is still draining fast it means that there's still a problem, maybe with your background processes or something else.
    07-01-2015 01:13 PM
  8. jeremmar's Avatar
    Makes sense... Thanks
    07-01-2015 01:24 PM
  9. sparksd's Avatar
    He didn't clear the app cache with this procedure - it's system cache.
    07-01-2015 01:27 PM
  10. Javier P's Avatar
    Good point. There are some posts talking about wiping the cache partition and others about clearing cache (this usually refers to apps cache). I'm not sure which one of these methods were used for any poster. I'm aware that they are different processes, but in both of them the deleted cache has to be built again.
    07-01-2015 01:35 PM
  11. Rich Homie Wayoe's Avatar
    Hey, guys.
    Since "upgrading" to Lollipop I have been doing all I could to fix the overheating and battery drain issues that it introduced to some people's Note 4s.
    I downloaded GServiceFix from the Play Store today and thus far, it seems to solve the issues that none of the aforementioned have done for me.
    Touch wood that this isn't premature, but my phone is actually performing like the device that I feel Lollipop was meant to make it be like. I have been so happy with the performance of my phone that I had to register on these forums just to help if possible.
    Good luck!
    07-02-2015 05:32 PM
  12. atlsport's Avatar
    I think my bad battery (since lollipop install) is due to weak signal from AT&T. See attached screenprint. I live/work in Midtown/Buckhead Atlanta, so not exactly out in the boondocks.The no signal part of the Mobile Network Signal (on the screenshot), I was at the gym, phone was in airplane mode. The rest of the line is yellow. When I get a solid green line there, I have GREAT battery (though it rarely happens these days).
    I've done the cache clearing and just about everything else, nothing helps.
    My signal strength is usually -89 to -93dBm 50asu. I have no idea if that's good or bad.
    If battery issue, delete cache, fixed my battery issue-screenshot_2015-07-02-22-29-13.jpg
    07-03-2015 09:21 AM
  13. sparksd's Avatar
    Absent a runaway app, I've found that a poor signal causes the radio to be far and away the greatest battery drainer on my Note 4 (or most any other phone).
    07-03-2015 09:28 AM
  14. Javier P's Avatar
    Yep. A bad signal is going to take a lot of battery juice.
    07-03-2015 09:51 AM
  15. jeremmar's Avatar
    Seems like after a few days my battery life is back to normal....
    07-06-2015 08:31 PM
  16. Gunny94's Avatar
    Cleaning cache partition always fixes my problems with battery life, or the phone slowing it down itself. Sometimes clearing the system cache helps a lot to get a refresh on it.
    But then again, if you update your phone doing this is a must.. (I just factory reset to make sure)
    07-18-2015 03:54 AM
  17. L_E_O's Avatar
    I think I'm in the Note 4 Lollipop = crap AT&T signal camp also. I also use an unlocked Moto X 2014 on AT&T, and it consistently has a better signal than the Note 4 even in terrible locations... like 3 bars "4G LTE" vs 1 bar "4G".
    If the phone signal is the cause, that would be included in Android Kernel and Android OS in the app usage listing, right?
    07-23-2015 02:48 PM
  18. f5air's Avatar
    just did on mine!.
    07-26-2015 10:51 PM
  19. Rometheus's Avatar
    Have done everything on here twice. Also have power saving mode on and unchecked my connection optimizer and after a week and half of having this phone well on Lollipop, this is my average battery life. I'm seriously contemplating selling my Note 4 now. Also my Note 4 has been on for 40 minutes with minimal use and it was at 100%. If battery issue, delete cache, fixed my battery issue-uploadfromtaptalk1438173653987.jpg
    ~Blessed From My Note 4~
    07-29-2015 08:41 AM
  20. atlsport's Avatar
    I ended up doing a system wipe and reinstalled everything. What a pain. Good news is battery life is great again. That 'Awake' line on the battery screen used to be solid. Now it's only awake when I'm using it. Also my screen had been getting warm/hot a lot. None of that in the 2 weeks since I dis the wipe. It was a pain, but happy to have my battery life back.
    07-29-2015 11:46 AM
  21. Rometheus's Avatar
    Okay just checked my battery again and look at this......if it was like this all the time.
    jerseygirl likes this.
    07-29-2015 06:36 PM
  22. TechNut79's Avatar
    Why does my battery screen not show how long I've been on battery like some of you do? Is it because I'm on Verizon and they removed it?
    07-30-2015 12:44 AM
  23. spotnjack's Avatar
    After you open the initial battery screen, tap the graph and that will take you to the screen that shows how long you've been on the battery.
    07-30-2015 05:08 AM
  24. TechNut79's Avatar
    Nope. Mine doesn't have how long it's been on battery anywhere. Must be awesome Verizon. They take away everything.
    07-30-2015 11:39 AM
  25. spotnjack's Avatar
    Huh, I'm on Verizon and mine works.
    07-30-2015 12:46 PM
173 ... 34567
  1. Note 4 Sprint~ Where is SN? Anyone else have this issue?
    By nightbird81 in forum Samsung Galaxy Note 4
    Last Post: 02-10-2015, 03:18 PM
  2. Where is my on my calculator on my Samsung Galaxy 3 tablet?
    Last Post: 02-10-2015, 09:09 AM
  3. How do I go about checking the age of my Galaxy S4?
    Last Post: 02-10-2015, 08:36 AM
  4. Replies: 1
    Last Post: 02-10-2015, 08:19 AM
  5. If someone stole my phone can I track it ?
    Last Post: 02-10-2015, 07:11 AM
