1. Porkchopexpress1969's Avatar
    How is the call quality on the Note 4? I hear all the reviews on camera and other stuff. Not a ton on call quality.
    Thanks!
    robert
    02-10-2015 07:12 PM
  2. NickA's Avatar
    I think that's good that you don't hear a lot about it. People usually post when things are bad, not good.
    I don't have any issues with mine (Verizon), and people on the other end have no complaints. Not directly related to call quality, but when I have sunglasses on and hold the phone up to my ear, the arm of the glasses keeps the phone away from my ear because of the width of the phone. Not a big deal but annoying sometimes.
    02-10-2015 07:16 PM
  3. russel5150's Avatar
    My call quality is great im in an area with strong verizon signal, so the connection is good. Good loud sound and everyone seems to hear me ok even when the speakerphone is on and im driving. I actually quit using my old bluetooth speaker because the volume of the speaker on the 4 is much louder than the note 2 and 3.
    Verizon Note4 w/ Tech 21 case
    02-10-2015 11:25 PM
  4. Porkchopexpress1969's Avatar
    Good info.... Thank You.
    02-10-2015 11:33 PM
  5. Android D's Avatar
    Yeah it's been great for me and I am on verizon...going to be 4 months now with Note 4!
    02-11-2015 01:00 AM
  6. NexusGirlX's Avatar
    I have T-Mobile. There are times when I call someone and the sound is crystal clear and other times when it's a normal call, not bad but not crystal clear. I'm not sure if the crystal clear ones are also on T-Mobile or if they are using WiFi calling but it just sounds amazing. To be fair, I also experienced the same thing on my iPhone 5S.
    02-11-2015 02:09 AM
  7. atcach's Avatar
    I come from an s3. Note's call quality is way better in both ends
    02-11-2015 04:06 AM
  8. qbnkelt's Avatar
    Call quality is excellent. I've got an SGS5 issued through work and the Note 4 is much much better.
    Sent from my gorgeous sexy white BEAST of a Note 4 ❤
    02-11-2015 06:07 AM
  9. Tatt2014's Avatar
    I'm also on Verizon,and the call quality is Excellent!!!
    02-11-2015 06:30 AM
  10. Porkchopexpress1969's Avatar
    I will on ATT, never had an issue with my iphone5 for quality. Sounds like the Note 4 is wood be good also.
    02-11-2015 07:54 AM
  11. barrettdaniel's Avatar
    I find call quality excellent on my N4.
    02-11-2015 08:47 AM
  12. Haalcyon's Avatar
    Call quality on all my recent phones, Note 4 included, has been good enough to just take for granted and not even consider.
    from the 🔪 Edge📱
    02-11-2015 08:54 AM
  13. Max Nix's Avatar
    Note 4, Verizon. Excellent on both ends.
    02-12-2015 01:48 PM
  14. LaTuFu's Avatar
    from the Edge
    I think this is about as accurate of an answer as you can get.
    The Note 4 is as good as any other Galaxy device I've ever owned, and in some respects it is very much improved. They've all been very good phones from a call quality perspective.
    The only major difference with the Note 4 over my S4 is positioning the phone if I am not using a headset or earbuds. If I am holding the phone up to my ear, due to its size, I have to make sure I hold it at a particular angle or the mic doesn't pick up my voice well. (According to the feedback from my wife). With earbuds or Bluetooth in my car, however, it is one of the best phones I've ever had.
    02-12-2015 02:36 PM
  15. dpham00's Avatar
    Call quality is good, even in underground parking structure. Way better than my Motorola phones.
    Sent from my Verizon Samsung Galaxy Note 4
    02-12-2015 07:34 PM
  16. Android D's Avatar
    You have good coverage with T-mobile where u r @ ??
    02-12-2015 07:36 PM
  17. BoiseBroker's Avatar
    Signal strength is currently worse than Note 2 on Sprint throughout the Boise area.
    I called to complain today and Sprint suggested I change settings to not use LTE (which will put data back to 3G) to improve phone reception. I am looking for a better solution.
    02-12-2015 08:13 PM
  18. Brian W1's Avatar
    I have had the S3,S4,S5,Note3,iPhone 4s,iPhone 5s and now have had the Note 4 for about 2 months. I love this phone. At my house Verizon is kinda weak. The Note 3, S3, and S4 were not good inside my house at all. They would work, but some days they'd drop calls, or break up. The reception of the 2 I Phones was great as was the S5. The Note 4 is as good or better than all of them. Places I used to drop calls, the Note 4 doesn't even break up. It seems to me Samsung listened and fixed the weak signal and weak speaker of the Note 3 on the N4. I am very happy with it and plan on keeping it. I know that's not really call quality, but thought it was an important (NOTE)...lol
    02-13-2015 01:45 AM
  19. Android D's Avatar
    Weak verizon reception in YOUR HOUSE? ur home made out of lead walls or something? lol
    02-13-2015 12:16 PM
  20. Almeuit's Avatar
    It is great for me on T-Mobile.
    02-13-2015 12:19 PM
  21. Almeuit's Avatar
    It is not uncommon for a carrier to have a weak signal in homes. This is why they make things like extenders. Even Verizon has one.
    02-13-2015 12:20 PM
  22. Brian W1's Avatar
    I think it has to do more with my tinfoil roof covered with armadillo shells
    02-14-2015 05:18 AM
  1. Replies: 5
    Last Post: 01-18-2017, 10:49 AM
  2. Why has my Yahoo mail stopped working on my Galaxy S4?
    Last Post: 04-24-2015, 12:18 PM
  3. Why has my auto-rotate stopped working on my phone?
    By Dreamspinner3 in forum LG Optimus Series
    Last Post: 03-14-2015, 01:23 PM
  4. How do I delete pictures from Oicasa on my Galaxy S5?
    Last Post: 02-10-2015, 08:03 PM
  5. How do I find the print queue on LG G2?
    Last Post: 02-10-2015, 07:01 PM
