03-05-2015 03:13 PM
69 123
tools
  1. Closingracer's Avatar
    Seriously I don't get why it's eating so much battery. Pretty poor battery life considering my note 3 lasted longer
    Sent from my SM-N910V using Tapatalk
    02-12-2015 07:53 AM
  2. bbmjack's Avatar
    Do you have KNOX app on your phone ?
    KRASIVA
    02-12-2015 08:00 AM
  3. Bluepython9286's Avatar
    I don't get why people call a battery "terrible" if it doesn't go 2 days or further. It gets me through the day without having worry, and I plug it in at night. Maybe there is something I'm not seeing but all. The posts I see everywhere about this. Come off as just trying to have something else to complain about. It's a good phone, none will ever be perfect.
    02-12-2015 08:05 AM
  4. Closingracer's Avatar
    Lol because it's terrible ? I average 1 hour and 30 minutes of screen time sometimes going to 2 hours when the note 3 I had gotten as high as 4 under the same settings and etc . The battery life is horrible and has been for a while
    Just look at how steep it's dropping off .... The battery life is TERRIBLE
    02-12-2015 08:27 AM
  5. LaTuFu's Avatar
    I'd say you probably have some settings that could be adjusted.
    "Terrible battery life" is not one of the descriptions I would use with a Note 4. It has been consistently demonstrated to be one of the best performing phones on the market from a battery life standpoint.
    The on screen times you're claiming are well below what most people are experiencing (including me) who are getting better battery life.
    At the same time, a nearly 2 day standby time is pretty solid performance by just about anyone's standard.
    Based on the fact you're getting good standby but lower than average on screen, I'd lean towards personal setup more than "this phone has terrible battery life."
    02-12-2015 10:34 AM
  6. Closingracer's Avatar
    I average that even when I use my phone...the screen time
    02-12-2015 10:36 AM
  7. LaTuFu's Avatar
    That's my point. If you are only getting 90 minutes of screen time, you can probably stand to adjust your settings.
    I average 4-6 hours of screen time, and I think most users are somewhere in that range as well.
    I don't run power saving settings or use battery apps.
    02-12-2015 11:24 AM
  8. Closingracer's Avatar
    Why should I ? Same settings I've done on all my phones and this is the only one with the issue
    02-12-2015 11:27 AM
  9. LaTuFu's Avatar
    Every phone is different. I have to drive my 4 cylinder car much differently than I do my wife's 8 cylinder Jeep, even though I'm on the same road.
    It's your phone, though, do as you please. Just understand the problem you are having is due to user preference, not system design flaw.
    02-12-2015 11:36 AM
  10. Closingracer's Avatar
    It is a system design flaw though ......I was averaging 4 hours till about a month ago ....it's the dumb phone and I Know it
    02-12-2015 11:41 AM
  11. sbhatia1981's Avatar
    Your phone is continuously awake, I will guess google now is draining your battery, try to disable it and location reporting for day and see if that makes any diff.
    Also install gsam battery monitor to see which app is using battery.
    Note 4 has 1 of the best battery, I continuously get 5/6 screen home time and 1d standby, with GPS and sync and everything on. It is not system flaw I can assure you!
    02-12-2015 11:54 AM
  12. bassplayrguy's Avatar
    Considering you are in the overwhelming minority and everyone is getting great battery life but you then it may just possibly something going on with your unit or settings, not the Note line.
    KevroniCoal and LaTuFu like this.
    02-12-2015 01:34 PM
  13. Closingracer's Avatar
    Considering you are in the overwhelming minority and everyone is getting great battery life but you then it may just possibly something going on worth your unit or settings, not the Note line.
    Settings? I've said it isn't my settings ....and these settings are the same with all my android phones and yet it now an issue ? I have location on , 65% brightness and data and always got around 4 hours of screen time on my note 3 for about most of the time till around the end and till December on my note 4 ....it's the phone not me
    02-12-2015 01:36 PM
  14. LaTuFu's Avatar
    Based on the responses in the rest of this thread, using facts and logic will have no effect. I admire your willingness to keep trying.
    KevroniCoal, rabernet and jayk82 like this.
    02-12-2015 01:39 PM
  15. Closingracer's Avatar
    Logic ? My logic is sound ....my note 3 and note 4 had the same things on like data , location and screen brightness and given the note 4 is newer it should be on par at least . It's Apple to oranges but I had a Samsung Galaxy Tab s 10.5 and it lasted 4 hours with all that on but my iPad Air 2 lasts around 7-9 hours of usage with 65% brightness , location, cellular all on
    I also never had this problem with the t-mobile variant I had for a few weeks
    02-12-2015 02:02 PM
  16. LaTuFu's Avatar
    Yes. Logic.
    It would be one thing if you were saying "hey, used to have great battery life, after update now I don't. I've tried changing everything I can think of, nothing is helping. What do you guys think?"
    Instead, what you're saying is "hey, used to have great battery life, after update now I don't. it must be the phone's fault and therefore it's bad."
    A couple of us have offered up "it is very possible it isn't the phone, have you considered changing some of your settings?" to which your reply is "it isn't the settings. I haven't changed them and I am not going to. I know it's the dumb phone."
    Great. You're convinced you're right, in spite of a lot of anecdotal evidence on this forum that says you're not. No problem, keep that opinion if that's what you want to do. But it goes against the general consensus of the knowledge and first hand experience accumulated in this forum, let alone many other android/Galaxy Note 4 fan sites.
    So your opinion does defy logic to some of us. That's all.
    02-12-2015 02:10 PM
  17. Closingracer's Avatar
    Yes. Logic.
    If I need to change how I use my phone to meet its demands it's the phones fault not mine ...I know how much battery life I should get out of it and if it decreases from previous use I'll just dump it for another phone . The t-mobile variant note 4 and note 3 have the same settings and lasted around 4 hours ....the Verizon one can't now .... Not going to turn crap off so I can have a phone to use sorry .
    02-12-2015 02:26 PM
  18. Ntchwaidumela's Avatar
    You do understand that this is not all your previous phones, right? You're getting damn near 2 days of battery life and you're complaining? Do you make calls on your phone? Browse? Read emails? Send messages? Just what do you use your phone for? I certainly hope you're not upset that you have to charge your phone every other day. I'm sure there may be a phone available that gets more battery life than the Note 4. If you're not happy with what most Note 4 owners consider to be excellent battery life, do some research and get one of those. Your complaint has no validation, IMHO.
    02-12-2015 02:37 PM
  19. Closingracer's Avatar
    My complaint is valid 100% ....I don't typically get 2 days .....I typically get 15 hours most and seen it drop as low as 6 hours . Screen time is the most important and 1 hour and 40 mins is crap which I do average no matter he standby time . I AVERAGE 1 HOUR AND 40 MINUTES OF SCREEN TIME .....that's just terrible and I'll keep complaining about that crappy battery life
    02-12-2015 02:50 PM
  20. LaTuFu's Avatar
    I'm bowing out of this thread after this, it's pointless...
    You are getting the screen time performance because you refuse to sit down and look at your settings. Many other VZ users are reporting 4-6 hour screen times. You used to have them, too, until an update changed one of your settings. Now you refuse to find out what.
    Complain all you want, but it isn't the phone. At this point, it is clear that it is all user error.
    jayk82, jacker, ShaggyKids and 5 others like this.
    02-12-2015 02:58 PM
  21. Closingracer's Avatar
    No update changed my settings .....it's not user error and the phone
    02-12-2015 03:03 PM
  22. V J's Avatar
    May I ask what you're actually trying to accomplish with this thread? You've obviously made up your mind to ditch the phone because of some battery life anomaly. You're evidently not open to any ideas and you're not really seeking help regarding solving this issue so what gives? What is the point of this thread??
    I'm almost tempted to come to the conclusion that you're simply WHINING for the hell of it but that can't be it because most humans would've grown out of the compulsion to whinge out their frustrations before they even begin learning how to use electronics!
    I myself average 3 hours of screen time and almost a whole week on standby combined so don't go crying that the phone sucks. Accept the fact that you either got a lemon or you're suffering from a wake lock issue but if you have no intention of dealing with it, then be a grown-up and switch phones and spare the world from this incessant moaning.
    02-12-2015 06:21 PM
  23. Max Nix's Avatar
    I totally agree. 43 hours on your phone is terrible...sheesh
    02-12-2015 10:03 PM
  24. Max Nix's Avatar
    That cracked me up. You're really funny.
    ShaggyKids likes this.
    02-12-2015 10:05 PM
  25. Aziel Oropeza's Avatar
    If you want a phone that'll last you a week without charging, you're obviously in the wrong place my friend
    Sent from my Rooted, Debloated GS3 using Tapatalk 2
    02-12-2015 11:47 PM
69 123
  1. LG G3 - 6k mAh battery
    By kaptanp3 in forum LG G3
    Last Post: 08-31-2015, 02:12 AM
  2. Lollipop update battery drain
    By moodylane in forum LG G3
    Last Post: 03-25-2015, 04:00 PM
  3. Replies: 2
    Last Post: 02-12-2015, 06:44 PM
  4. Lockscreen change after update - How to revert?
    By Andrew Lynch in forum HTC One M8
    Last Post: 02-12-2015, 08:13 AM
  5. How to RESET SG Tab 2 10.1?
    By Jellal in forum Samsung Galaxy Tab 2 10.1
    Last Post: 02-12-2015, 07:11 AM
