1. 420benz's Avatar
    What setting is required to turn this on?
    02-12-2015 03:36 PM
  2. SpookDroid's Avatar
    are you getting that error in any search?
    Those settings are usually for Phone searches only, and they're in the Google app's Settings, Phone Search. But you shouldn't need a special permission just to search the web.
    02-12-2015 03:47 PM
  3. 420benz's Avatar
    I was searching this. How to open all emails in my browser
    02-12-2015 03:53 PM
  4. 420benz's Avatar
    I just tried another unrelated to phone search and no problem
    02-12-2015 03:55 PM
  5. SpookDroid's Avatar
    Then probably the 'in my browser' tripped it. Make sure that on the PHONE search options you have the Browser and History option enabled.
    02-12-2015 03:58 PM
  6. 420benz's Avatar
    Ok I will try to find it.
    02-12-2015 07:19 PM
  7. SpookDroid's Avatar
    They shouldn't be hard to find. In the Google app just tap the menu button, go to Settings, and find Phone Search. There you'll have some options as to what you're allowing the app to search into.
    02-13-2015 10:43 AM
  8. 420benz's Avatar
    Is this what you are talking about?
    02-13-2015 09:20 PM
  9. SpookDroid's Avatar
    Yes...but for some reason you're not showing all options! I have apps, Chrome, Contacts, Play Books, Movies, and Music. Of course, I have all those 'extra' apps installed. Do you have Chrome installed in your phone?
    02-16-2015 11:05 AM
  10. 420benz's Avatar
    No.
    02-16-2015 11:45 AM
  11. SpookDroid's Avatar
    That might be why, then... the word 'browser' is tricking Google into trying to search your browser, but I think the only one supported is Chrome. If you install it, that option should appear there, allowing you to search bookmarks and history from your Chrome browser.
    02-16-2015 12:28 PM
  1. Random reboots and shutdowns. HELP!
    By cjohn4043 in forum Moto X (2013)
    Last Post: 02-12-2015, 06:00 PM
  2. Please help with hidden elements
    By Ignas12 in forum General Help and How To
    Last Post: 02-12-2015, 05:00 PM
  3. nexus 4 rebooting loop - help needed, started with lollipop, kitkat, and now cyangdenmod
    By runningman3433 in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 02-12-2015, 03:58 PM
  4. How do I get my pictures to show at a higher resolution?
    By smmnsk in forum General Help and How To
    Last Post: 02-12-2015, 03:46 PM
  5. Question about Internet and MMS Settings.
    By venom0706 in forum General News & Discussion
    Last Post: 02-12-2015, 03:18 PM
