1. NeilWhitear's Avatar
    Hi.
    Does anyone know what DCM Provider does?
    My Note for with Lollipop is suffering badly from battery drain (19%) recent charge from this app.
    I have tried restarting the phone to no avail.
    Help please?
    02-17-2015 12:05 PM
  2. Nitro211K's Avatar
    did you try a factory reset?
    02-17-2015 04:47 PM
  3. tcole16's Avatar
    Not sure what exactly it is, but I found a youtube video that had me go to my settings.
    Settings - Apps - All - DCMprovider - Force Close then Clear Data
    Then it should work for you!
    04-01-2015 04:23 PM
  4. B. Diddy's Avatar
    It's hard to find anything about it, but from what I can gather, it has to do with wi-fi. I found this little nugget in a firmware FAQ from Actiontec, which makes Screenbeam, a wireless display:
    (Q) What is DCM?
    (A) DCM stands for Different Channel Mode. DCM is a function of the wireless network adapter and its driver. It enables the system's wireless adapter to simultaneously operate multiple connections on different wireless channels, and supports applications such as Wi-Fi infrastructure and Wi-Fi Direct.
    However, this doesn't mean that I know for sure why DCM Provider is causing problems. I'd suggest a cache partition wipe to start with, which won't erase any personal data: https://support.t-mobile.com/docs/DOC-28932
    12-10-2016 04:08 AM
  5. AndreaNocco's Avatar
    Dcmprovider is linked to connection and to DownloadBooster mode. Try to disactiveted it first.
    01-31-2017 09:03 AM
  1. How can I remove Lollipop from my cell phone?
    Last Post: 11-27-2015, 07:54 AM
  2. Replies: 1
    Last Post: 02-19-2015, 02:50 AM
  3. G3 lollipop update AT&T
    By Bilal9209 in forum LG G3
    Last Post: 02-17-2015, 10:57 AM
  4. Replies: 0
    Last Post: 02-17-2015, 08:59 AM
  5. Why is my battery draining so quickly?
    Last Post: 02-17-2015, 08:57 AM
