Save big + get 3 months free! Sign up for ExpressVPN today
  1. latinking91's Avatar
    I'm trying out power saving mode and I'm a power user and my battery life is just even more powerful now. I'm barely on 60% and I already have over 3hrs of SOT time This phone is a beast.
    Posted via My Note 4
    02-17-2015 01:27 PM
  2. Almeuit's Avatar
    Nice!
    02-17-2015 02:22 PM
  3. AlfBriggs's Avatar
    Screenshots?
    02-17-2015 02:28 PM
  4. latinking91's Avatar
    Attached Thumbnails power saving works and doesn't intrude.-screenshot_2015-02-17-12-37-48.jpg   power saving works and doesn't intrude.-screenshot_2015-02-17-12-37-41.jpg   power saving works and doesn't intrude.-screenshot_2015-02-17-12-37-38.jpg
    02-17-2015 02:41 PM
  5. latinking91's Avatar
    And I constantly use my phone.
    02-17-2015 02:42 PM
  6. barrettdaniel's Avatar
    I've never tried Power saving mode before. What does it affect or how does it work?
    02-17-2015 08:02 PM
  7. Bosbouer's Avatar
    It can restrict background data
    It can restrict cpu performance, screen timeout, turn off all locations settings
    And more. At least the options can be juggled to some extent.
    02-17-2015 10:49 PM
  8. Android D's Avatar
    3.5 hrs of use and you are down to 57% !! Wow! Ok I know u use ur phone a LOT as u said, but to me I think that's still terrible battery life after having power saving mode on.
    When u say a LOT, what do you mean? what r u doing with your phone during this time if u don't mind sharing?
    02-17-2015 11:39 PM
  9. latinking91's Avatar
    Well without power saving mode on I was getting like 4 hrs maybe 5 hrs of sot time but I've gotten like an hr and some change extra of sot time with it on. This is my phone right now at 6% power saving works and doesn't intrude.-screenshot_2015-02-17-23-32-02.jpg and I posted another pic of the four different options for power saving mode power saving works and doesn't intrude.-screenshot_2015-02-17-23-31-46.jpg
    Attached Thumbnails power saving works and doesn't intrude.-screenshot_2015-02-17-23-31-37.jpg   power saving works and doesn't intrude.-screenshot_2015-02-17-23-29-40.jpg
    02-18-2015 12:36 AM
  10. Android D's Avatar
    Well without power saving mode on I was getting like 4 hrs maybe 5 hrs of sot time but I've gotten like an hr and some change extra of sot time with it on. This is my phone right now at 6% Click image for larger version.
ID:	163767 and I posted another pic of the four different options for power saving mode Click image for larger version.
    I am usually over a day use with 6% charge left...and NO power saving mode.
    But then I don't describe myself as a "heavy" user...My use is moderate @ best.
    But I guess with Heavy use that battery life is ok...I read earlier on this forum that with heavy use battery life should be around 12hrs on this phone!
    02-18-2015 01:37 AM
  11. AJErvin12's Avatar
    His post and screenshots show 14.5 hours on battery and 6.5 hours of screen on time with 6% battery left. Sounds decent, but not great to me. I'm getting similar usage from mine without power saving mode. I misread the screenshot at first.
    02-18-2015 03:55 AM
  12. anon(5816156)'s Avatar
    Wow! I would be lucky to have 5 hours and 30 mins of screen on time with power saving mode on.
    (Max I got was 5 hours 23 mins in 18 hours with perfect signal)
    02-18-2015 05:06 AM
  13. latinking91's Avatar
    I've seen someone on here get 8plus hours of sot, that's crazy. I wish I could get battery life like that but I'm happy with the 6hours I get, as long as the battery lasts me all day I'm good. And I use my phone for everything videos email messaging reading etc.
    02-18-2015 09:52 AM
  14. anon(5816156)'s Avatar
    And I decided to use it extensively with power saving on until it reaches 70%. What do you think folks?
    Attached Thumbnails power saving works and doesn't intrude.-screenshot_2015-02-18-23-00-27.jpg   power saving works and doesn't intrude.-screenshot_2015-02-18-23-00-36.jpg
    02-18-2015 10:01 AM
  15. Android D's Avatar
    U have pretty heavy usage...does ur phone heat up a lot? or does it feel warm everytime when u put it in your pocket?
    02-18-2015 01:05 PM
  16. bassplayrguy's Avatar
    Terrible battery life? On what planet? 6 plus hours of SOT is great battery life. This is on track to get over 7.
    latinking91 likes this.
    02-18-2015 02:28 PM
  17. bassplayrguy's Avatar
    That is pretty good considering you are on 3G and that isn't battery friendly.
    anon(5816156) likes this.
    02-18-2015 02:29 PM
  18. latinking91's Avatar
    Its only felt warm like once or twice but usually it'll just cool down on its own. It's like a laptop they get hot and they need space to breathe. But not too hot where I would be worried. I consider warm normal
    02-18-2015 02:32 PM
  19. Android D's Avatar
    I was thinking more of just in terms of how long u can run on that battery without having to plug it in. No more in terms of SOT. But it's ok I now get the concept!
    bassplayrguy likes this.
    02-18-2015 03:14 PM
  20. Android D's Avatar
    makes sense...thanks for the info
    02-18-2015 03:15 PM
  21. anon(5719825)'s Avatar
    I get 4-5 hours of on screen time without using power saving and I am more than happy with that. Even on my Note Edge, I get 3-4 hours with it's smaller battery. I always keep WiFi off. I have unlimited data plans so I use them. I have found WiFi being on or off doesn't affect the battery.
    My last Android phone was a Nexus 4 and I was luck to get 1 hour of screen time.
    02-18-2015 04:44 PM
  1. Replies: 2
    Last Post: 03-20-2015, 11:49 PM
  2. How do I get my wifi working?
    Last Post: 03-20-2015, 11:42 PM
  3. Why can't I print PDF's saved on Phone?
    By RobIV01 in forum Samsung Galaxy Note 4
    Last Post: 02-20-2015, 12:58 PM
  4. Replies: 2
    Last Post: 02-19-2015, 04:16 AM
  5. How To Save?
    By knotez1 in forum General Help and How To
    Last Post: 02-17-2015, 12:44 PM
