1. MicahAlman's Avatar
    I've had my Note 4 for roughly two months and the battery life lasted all day up until a couple weeks ago. I always had my phone set to auto-brightness, without Bluetooth or location on, but my wifi was always on. After awhile, the battery life seemed to decrease until one day I turned off my auto-brightness and set the brightness to a little less than half. For some reason, this change added hours to my battery life. I'm curious to know if this is a solution or problem that anyone else has used or had.
    Thanks, Micah.
    02-18-2015 01:22 PM
  2. z06mike's Avatar
    Depending on how and where you use phone, it may be better to use a static brightness level, as opposed to constantly being turned up and down by the Auto Brightness. This is probably why you have seen better battery life.
    02-18-2015 01:35 PM
  1. Recommended replacement battery
    By OpalOtter in forum LG G3
    Last Post: 02-06-2017, 11:54 PM
  2. Replies: 5
    Last Post: 03-07-2015, 08:57 AM
  3. Normal Battery life?
    By Alter Poser in forum Sony Xperia Z3
    Last Post: 02-24-2015, 06:49 AM
  4. Replies: 0
    Last Post: 02-18-2015, 01:07 PM
  5. Replies: 2
    Last Post: 02-18-2015, 10:07 AM
