1. PlanetPluto7's Avatar
    My Note 4 will not stay out of pin lock. Changing to another method either will not work at all or will only apply one time before pin lock is back. I used fingerprint for a while but when I wanted to go back from PIN this started. Swipe will work one time before going back to PIN.
    02-20-2015 03:51 PM
  2. Nitro211K's Avatar
    two possible causes for this. And one solution that will most likely fix this.
    Reason #1: you may have activated Knox, and the method of Knox PIN is taking over.
    or
    Reason #2: If you are trying to get your corporate e-mails on your phone, most likely your company is forcing the PIN method as security(most companies do)
    The fix: I hate to say this, but you may have to do a factory reset(try a battery pull first), but if that doesn't work, then a factory reset might be the way to go.
    beh likes this.
    02-20-2015 04:25 PM
  3. Android D's Avatar
    sorry to hear this...I have been using Finger scanner for sometime now, realize it's getting annoying to I am going back to swipe...I hope i don't have this issue, but keep us posted if u find a fix!
    02-20-2015 10:03 PM
  4. z06mike's Avatar
    Have you by any chance had FoxFi installed?
    02-21-2015 01:01 PM
  5. PlanetPluto7's Avatar
    I have been on swipe without it going back for half a day. I just kept trying to change it. Gonna enjoy this another half day and then try fingerprint again
    02-21-2015 07:12 PM
  6. PlanetPluto7's Avatar
    Nope.
    02-22-2015 06:58 PM
  1. Replies: 11
    Last Post: 05-08-2016, 02:18 PM
  2. Replies: 4
    Last Post: 03-25-2015, 04:17 PM
  3. Cool rendering of the S6 and S6 Edge
    By worldspy99 in forum Samsung Galaxy S6
    Last Post: 02-20-2015, 10:58 PM
  4. Replies: 0
    Last Post: 02-20-2015, 03:01 PM
