1. Syn1cal's Avatar
    The other day Power Clean said my device temperate was over 140 degrees, which I find pretty alarming.. normally its in the 100-120 range while using it and in lock/idea state its around 80 degrees. Well, the phone starts doing some funny things at high temperatures. Programs stop responding, and the device gets sluggish... Does anyone else have overheating issues?
    02-24-2015 03:43 PM
  2. Rukbat's Avatar
    Recent update and didn't clear cache?
    If not, any unusual long wakes? Anything running in the background?
    Assuming the ambient temperature isn't around 95 degrees (the higher the temperature in the room, the higher the phone temperature - cooling depends on temperature difference), my next suspect would be the battery. Open it, pop the battery and see if that's what's warm, and if the battery compartment cools off faster than the battery.
    02-24-2015 03:49 PM
  3. SpookDroid's Avatar
    None whatsoever here. T-Mobile Note 4. Maybe a rogue app you're using?
    02-24-2015 03:51 PM
  4. Syn1cal's Avatar
    perhaps maybe Lookout antivirus? ill have to see
    02-24-2015 04:24 PM
  5. SpookDroid's Avatar
    I've heard a couple issues before with Lookout, especially when using SD Cards (apparently it scans too much? )
    02-24-2015 05:28 PM
  6. NexusGirlX's Avatar
    I pretty much just ignore Power Clean. I've turned on my Note 4 and within a second it popped up and told me my phone was over heating and the case feels ice cold. Ignoring it hasn't messed up my phone. I think the app is garbage myself. I think I'm going to remove it. My boss recommended it and that's the only reason I have it.
    02-24-2015 07:19 PM
  1. SMS issues since Lollipop
    By Jaggrey in forum HTC One M8
    Last Post: 02-27-2015, 12:30 AM
  2. Alarm issues.
    By tsweeney77 in forum Samsung Galaxy S5
    Last Post: 02-25-2015, 11:36 AM
  3. Issue with auto-bright feature
    By dmateo in forum Samsung Galaxy Note Edge
    Last Post: 02-25-2015, 08:28 AM
  4. Replies: 3
    Last Post: 02-24-2015, 04:45 PM
  5. Browsing issue.
    By kpdx in forum Samsung Galaxy Note 4
    Last Post: 02-24-2015, 04:20 PM
