1. iOSConvert2k14's Avatar
    Recently my Note 4 has been charging beyond 100% (or at least according to the status bar). The unplug charger battery full message won't come on until 5 minutes or longer. Anyone else notice this? gsam battery says it's full but the phone hasn't alerted me yet.
    02-25-2015 12:00 AM
  2. Rukbat's Avatar
    The "State of Charge" isn't really the SoC, it's the voltage across the battery terminals. (The true SoC can only be determined by taking the battery apart and chemically analyzing it - which also destroys it. Measuring the voltage is the best we can do - and it's an estimate, based on how we know lithium batteries work.) When the charger is connected, the terminal voltage on the battery is higher, so when it says 100% on the status bar, it's not yet fully charged. The phone waits until the voltage gets to the "100% with the charger attached" point before telling you that it's fully charged. (At which point, charging stops, so you don't have to yank the charger out. Leaving it plugged in for another month won't do any damage.)
    If you unplug the charger the moment the status bar hits 100%, you'll probably notice the indicator drop to 99% very quickly. That's because that was the true SoC.
    (BTW, what email app are you running? I'm running the same one, but I can't find a link to it anywhere, or any reference to it in the phone, except the icon.)
    02-25-2015 12:17 AM
  3. pappcam's Avatar
    I had no idea that battery charging was such a confusing and contentious issue for so many people.
    I have no idea why people seem to over-think such a basic function of their phone. Just plug it in and don't worry about it.
    worwig likes this.
    02-25-2015 08:06 AM
  4. iOSConvert2k14's Avatar
    Thank you for your detailed battery explanation! As for your email question: Just the stock email app the phone came with. It's great because I can use multi window with it. Tried others but the stock is best for email imo
    02-25-2015 08:51 AM
  5. iOSConvert2k14's Avatar
    I slipped on ice and my Note went flying out of my hand this weekend. The bottom of my phone got scuffed, even in an Otterbox (hit the ground hard). It never did that until last night, which prompted me to ask other users in hopes that I didn't damage anything internally during my fall.
    02-25-2015 08:53 AM
  6. Rukbat's Avatar
    Cars are the same thing. Why the big deal about changing the oil? It still has oil, right? Just drive it.
    If you want to keep buying new batteries, and complaining about the terrible battery life this phone or that update gives you, just "use" the phone (in quotes, because it's actually abuse, not use.). If you want the battery to outlast the phone, and get almost 2 days between charges from any phone in light to moderate use, learn how to use the phone.
    02-25-2015 04:20 PM
  7. pappcam's Avatar
    Cars have have actual documented recommended maintenance intervals that aren't based on hearsay from anonymous internet people so that's a horrible comparison.
    I had my S3 for over 2 years plugged in every night as it's my alarm clock. The battery still seems to hold the same amount of charge as it did when it was new. I have no idea why anyone would want or even think about wanting "the battery to outlast the phone". That doesn't even make sense.
    02-25-2015 04:36 PM
  8. bassplayrguy's Avatar
    This makes no sense
    02-25-2015 05:29 PM
  9. dpham00's Avatar
    It isn't really 100% full when it reaches 100%.you can use battery monitor widget to log and see when the charging actually stops.
    Sent from my Verizon Samsung Galaxy Note 4
    02-25-2015 05:29 PM
  10. ChemMan's Avatar
    For what it is worth, my Zerolemon battery spent probably 6+ hours at 100%. In the Zerolemon instructions it said to charge the battery for 12 hours. Didn't mention to unplug at 100% It did say to charge to 100& at least once a month.
    02-25-2015 08:38 PM
  11. ChemMan's Avatar
    I guess you could have changed the battery characteristics physically. I don't know how the battery is put together and of what material. I am sure if you smacked the battery with a hammer it would not charge the same as before you smacked it. Here is some reads for you though.
    A Designers Guide to Lithium Battery Charging | DigiKey
    Why lithium-ion-batteries fail
    First one is a little dated but still good information.
    iOSConvert2k14 likes this.
    02-25-2015 09:44 PM
  1. Replies: 3
    Last Post: 02-27-2015, 09:20 AM
  2. Why does my Google Play store keep crashing?
    Last Post: 02-25-2015, 12:51 AM
  3. Why does the battery charge slow and loose power fast?
    Last Post: 02-25-2015, 12:20 AM
  4. Charging
    By stilltwinston in forum Samsung Galaxy Note Edge
    Last Post: 02-24-2015, 07:25 PM
  5. Replies: 1
    Last Post: 02-24-2015, 02:45 PM
