1. frivolous carpet's Avatar
    Anyone switching on battery saving mode only to find the next time you look at your phone it has been disabled? Might be something I'm doing which auto disables it, but I can't figure out what. I haven't yet managed to keep it on for more than an hour or so.
    02-27-2015 04:04 PM
  2. srkmagnus's Avatar
    Battery saving mode might be initiated once the device reaches a certain battery level. If you are charging it and it reaches above that minimum it might turn off and return to a normal state. Or, battery saving could be automatically disabled at anytime during charging.
    03-05-2015 01:18 PM
  3. frivolous carpet's Avatar
    It seemed to be related to the ever decreasing battery life I was experiencing. Wiping cache solved both problems. Seems like a common issue with this phone.
    03-06-2015 04:28 AM
  1. How do I delete kids mode from my HTC One as I have no kids?
    Last Post: 07-27-2016, 05:24 PM
  2. Battery Life Lately
    By scruff24 in forum Sprint LG G2
    Last Post: 03-05-2015, 01:04 PM
  3. Replies: 1
    Last Post: 03-05-2015, 01:03 PM
  4. Replies: 1
    Last Post: 03-05-2015, 12:49 PM
  5. How to disable proximity sensor on non-rooted nexus 4?
    Last Post: 03-05-2015, 08:29 AM
