08-28-2015 01:40 AM
33 12
tools
  1. bassplayrguy's Avatar
    Is it just placebo or does this make thing snappier? I was cautious about doing this because it is a bit scary but after doing it, it seems quicker. Maybe it is just me?
    03-02-2015 08:48 AM
  2. Gekko's Avatar
    most people believe it works. i do. think of it like cleaning and decluttering the house - less crap for you to have to deal with, manage, and stumble through so you can live and operate more freely and easily.
    bassplayrguy and 21stNow like this.
    03-02-2015 08:56 AM
  3. Golfdriver97's Avatar
    I do a cache clear once per month in recovery on all my devices. Helps keep them working great. The cache clears do help, by getting rid of junk files that the OS doesn't need to look through.
    03-02-2015 08:57 AM
  4. D Android's Avatar
    I don't think it's placebo. From what I understand it gets rid of many temporary files generated by the apps and in my experience it does speed things up, however scary it may seems at first.
    bassplayrguy likes this.
    03-02-2015 09:04 AM
  5. LeoRex's Avatar
    Well... first.. you shouldn't worry about clearing your cache partition. The only way it'll kill you is if you pick the wrong partition.. I wasn't paying attention one time doing a clean flash and I clicked 'internal storage' instead of 'cache'.... but that was a fun story for another time.
    What does it do? Well, it isn't a placebo... clearing the could solve certain issues... I've had quite a few problematically FC'ing apps behave after clearing the cache. It isn't some miracle cure, but there is zero harm in doing it. As for your performance... clearing it may speed things up a bit, but only if there is some problem in the cache that is causing things to bog down... the process, in and of itself, doesn't speed up your phone.
    bassplayrguy and natehoy like this.
    03-02-2015 09:13 AM
  6. Kane89's Avatar
    Say Golfdriver97. What are the procedures of doing a cache clean on a sprint galaxy note 4 (SM-N910P) Model?
    Devil Dog
    03-02-2015 09:53 AM
  7. sparksd's Avatar
    Devil Dog
    See my post #2 in this thread:
    http://forums.androidcentral.com/sam...ery-issue.html
    03-02-2015 10:36 AM
  8. Golfdriver97's Avatar
    Devil Dog
    Looks like someone beat me to it...lol
    I often recommend a reboot to recovery because between the 2 reboots (1 to recovery, and 1 to Android) and the cache clear, that often fixes whatever issue is causing the problem.
    From an AOSP M8
    kanesmith41 and bassplayrguy like this.
    03-02-2015 02:18 PM
  9. GregMargie's Avatar
    sparksd, Thank you so much for mentioning this again, as I copied and pasted this to my Evernote awhile back, when you had posted these clear and exact instructions.
    Although other members are truly helpful and really mean well, they mostly say, "clear your cache partition" and don't always write out the exact instructions for people who have never done it before. A few days ago, a member was told to do this and I posted your exact instructions! I must admit, that I mistakenly forget to note in my saved file who was so generous to write it all out, and said that in my post, because I wanted to give credit where credit is due!! So now I know it was you and I wanted to say THANK YOU so much, because it was the first time I had done this procedure and you helped me to pass on the exact information to others now as well!!!
    03-02-2015 02:42 PM
  10. anon8380037's Avatar
    Golfdriver97 has been wiping cache partiitions since before babies could ****!
    (po + op)
    http://forums.androidcentral.com/sho...d.php?t=298808
    I do it for housekeeping - it's a first port of call for a problem, but I don't think people should be advised this will end a particular issue.
    Why Android doesn't just pop up a window every now and then to ask "do you want to clear your cache partiition in Recovery mode now? (recommended)" I will never know.
    Windows asks do you want to restart your device now, after an update.
    bassplayrguy and Golfdriver97 like this.
    03-02-2015 04:22 PM
  11. GregMargie's Avatar
    Great idea. Thant would be nice.
    anon8380037 and bassplayrguy like this.
    03-02-2015 05:05 PM
  12. sparksd's Avatar
    (po + op)
    [Guide] [Info] Custom recoveries versus Stock. Is there a difference? - Android Forums at AndroidCentral.com
    My guess is that they made getting to Recovery Mode difficult so people wouldn't get in there and inadvertently do something bad - like a factory reset when they didn't really want to. But yes, it would be nice if it were more convenient.
    03-02-2015 06:59 PM
  13. anon8380037's Avatar
    That's a good thing to point out. I had that worry when I first tried it after advice on here.
    The Recovery menu font is small, and Wipe Cache Partition (or whatever the wording) is one after Wipe Data/Factory Reset.
    However if Factory reset is accidentally highlighted and selected with the power button, you get another screen where you have to select 1 Yes out of 10 No's on the next screen, so you can't go wrong (unless you let a child near it!).
    From Golfdriver97's guide:
    Golfdriver97 likes this.
    03-02-2015 07:38 PM
  14. sparksd's Avatar
    Yes, you would think that it is ***** proof. I seem to recall having a custom ROM on another device that provided a"Restart in Recovery Mode" option in the power-down menu - that made it more convenient to get to.
    anon8380037 likes this.
    03-02-2015 09:50 PM
  15. Golfdriver97's Avatar
    I think almost all of them do. If not, it's called the Advanced reboot menu and is located in a couple different places. Something to consider about this point though: if you have flashed a custom ROM, it's almost taken for granted that you know how to get into recovery through the physical buttons.
    To put a different spin on things: I think this should be printed on a quick start guide.
    03-02-2015 10:38 PM
  16. dpham00's Avatar
    I usually just leave things alone until I notice a slow down. Though sometimes just clearing app cache fixes slow downs so I don't have to bother with going into recovery.
    03-03-2015 08:38 AM
  17. natehoy's Avatar
    In stock Android, Google even took away the "Power Down and Restart" option, presumably because they didn't want to imply that doing so was necessary from time to time.
    Personally, I think clearing the cache partition should be part of housekeeping at every shutdown, or at least have a setting in developer mode to do that. It's not like there's any data of value stored out there.
    03-03-2015 10:44 AM
  18. goin_nil's Avatar
    I wiped the system cache as in your linked post above.
    How long does it normally take? Mine was done in less than a second.
    Maybe I'm used to the slowness of the "Clear cached data" in settings. It can take several seconds, over a minute.
    03-05-2015 04:15 PM
  19. sparksd's Avatar
    It is very fast as the partition is not large, nothing like app caches can be.
    03-05-2015 04:20 PM
  20. natehoy's Avatar
    If it isn't happening almost instantaneously, something is wrong.
    In addition to the size, there's a huge difference as to what is happening between deleting cache data and wiping a cache partition.
    "Clear cached data" is going through a folder and deleting things file by file. The partition that folder is in has stuff that you do not want deleted - pictures, applications, user settings, and whatnot. The only way to delete the temp data is to blow it away one file at a time (think of clearing TEMP in Windows - that's basically what you are doing)
    "System cache" is a dedicated partition (sorta like a separate disk drive). It doesn't have to wipe any data at all. It just needs to reset the area that tells the system that stuff exists on the partition. That's literally changing a couple of thousand bytes at most. The data is actually still there but the OS doesn't know it exists, so it treats it all as empty space. (think of "Quick Format" in Windows - that's basically it).
    03-05-2015 04:56 PM
  21. anon8380037's Avatar
    That's interesting. I was going to add that both my Samsung's, a Note 3 and ex S2, do indeed 1 or seconds.
    So I was surprised that a Moto G I bought to replace the S2 took about 5 minutes or so, being almost vanilla Android and all.
    Are you saying the Motorola / Google devices do it properly then, where the Samsung's just put a vacant sign on the System Cache space?
    I didn't fully understand the post, but that's probably more me than your explanation.
    On Edit: I misread, thinking clearing cache fast meant something was wrong, I see you say if it doesn't clear quickly something is wrong.
    Time for a coffee, donut and Aspirin.
    03-05-2015 05:06 PM
  22. natehoy's Avatar
    The Moto G might be doing a secure wipe (actually overwriting the partition with a random pattern), though why in the heck they'd bother is beyond me unless you encrypted your device or something.
    I know my Moto X (2013 and 2014 both) did a clear cache partition pretty darned fast.
    03-05-2015 05:21 PM
  23. anon8380037's Avatar
    Naw. Straight up unencrypted XT1039 Moto G 2013.
    I have very little on it and rarely use it.
    I just timed it at 4 min : 10 secs.
    Probably like you said it's being more thorough and overwriting.
    03-05-2015 06:24 PM
  24. Golfdriver97's Avatar
    It can depend on the kernel on the speed of the Cache wipe. My N5 takes almost 10 minutes.
    03-06-2015 08:13 AM
  25. lukie80de's Avatar
    For the Archives. In my case wiping the cache partition solved the following problems so far:
    1. sluggish UI
    2. general delayed-audio file playing
    3. delayed or non-functioning google now search voice-recognition
    Now I will do a wipe after every new app install.
    08-27-2015 12:53 PM
33 12
  1. Replies: 24
    Last Post: 06-28-2018, 01:13 AM
  2. Phone wont boot possibly bad partition?
    Last Post: 03-10-2015, 06:33 PM
  3. Should I Wipe Partition Cache after 5.0 Update?
    By kgilbertsen in forum Samsung Galaxy S5
    Last Post: 03-02-2015, 08:11 AM
  4. App Cache Cleaner app
    By marios1441 in forum General News & Discussion
    Last Post: 03-01-2015, 03:19 AM
  5. Replies: 1
    Last Post: 03-01-2015, 01:14 AM
