1. jba1987's Avatar
    Hi all, hope this finds its way too all the people dealing with this issue like I'd been for the last 4/5 days since I got my Note4!
    You shouldn't have to remove lenses/change settings/factory reset, and after doing this it should fix the issue in all apps that utilize the camera (Snapchat and Instagram are the only ones I've tried but it's working! )
    In the ". . ." Settings, there's an option for "Metering Modes". Simply change this setting to Matrix or Spot, and any time you open the camera up again, after about a second, the focus will set for all-distance shots! In Matrix Mode I find it auto-focuses with a smaller depth-of-field, and Spot a wider one!
    Hope this helps!
    UniQue WerkX and geekaren like this.
    03-05-2015 01:55 PM
  2. kobe008's Avatar
    I do not use the camera a whole lot so I do not know much about it. I checked this setting and with HDR turned on the Metering Modes is greyed out. I always thought having HDR on is better?
    03-05-2015 02:07 PM
  3. calebleesdad's Avatar
    I too noticed that metering modes is not available though with HDR on. I had to turn off HDR to try matrix and spot modes. All in all I prefer HDR.
    03-05-2015 02:09 PM
  1. Getting into tech blogging for a career?
    By Jas_AFK in forum Ask a Question
    Last Post: 03-06-2015, 05:32 PM
  2. Replies: 1
    Last Post: 03-05-2015, 10:49 PM
  3. What should I replace my Nexus 7 2013 from OfficeMax with?
    Last Post: 03-05-2015, 06:11 PM
  4. Google+ question on Note 4
    By oldirty9014 in forum Samsung Galaxy Note 4
    Last Post: 03-05-2015, 01:49 PM
  5. Why won't my Galaxy Note 3 S pen work?
    Last Post: 03-05-2015, 01:28 PM
