1. Dankees's Avatar
    Suddenly, my battery is just dying so quickly. It used to rock!
    Now, recently, my Contacts application is just crashing all day, and I cannot figure out why or how to fix it.
    Has anyone else had this issue? Why is it happening? What can be done to fix it?
    Also, has anyone else noticed that the Swarm application is draining the battery and running in the background for no reason? When I check my battery stats, Swarm is running at 11% - and I haven't used it in like 7 hours. What the hell?
    03-06-2015 02:50 PM
  2. bbmjack's Avatar
    Screenshot your battery stats so we can check
    KRASIVA
    03-06-2015 03:22 PM
  3. Dankees's Avatar
    03-06-2015 03:36 PM
  4. bbmjack's Avatar
    Swarm is draining the battery crazy I recommend you to force stop it or unistall it.
    KRASIVA
    03-06-2015 03:43 PM
  5. Dankees's Avatar
    Yeah, I keep doing that. It doesn't seem to help.
    03-06-2015 03:46 PM
  6. bbmjack's Avatar
    In my experience about android system
    Do you have samsung my knox on your device installed from play store ?
    Location drains battery
    KRASIVA
    03-06-2015 03:47 PM
  7. stackberry369's Avatar
ID:	165999Click image for larger version.
ID:	166000Click image for larger version.
    what is swarm?
    03-06-2015 03:54 PM
  8. bbmjack's Avatar
    what is swarm?
    App I think similar to forsquare
    KRASIVA
    03-06-2015 03:58 PM
  9. Dankees's Avatar
    KRASIVA
    I don't use Knox. I'm not doing anything new, so I'm not sure why the battery is suddenly tanking.
    03-06-2015 05:40 PM
  10. Therealm80's Avatar
    The fix for the contacts crashing which worked for me was uninstalling google plus.
    Dankees likes this.
    03-06-2015 05:42 PM
  11. Dankees's Avatar
    Can I re-install it afterward?
    03-06-2015 05:43 PM
  12. bbmjack's Avatar
    Yes
    KRASIVA
    Dankees likes this.
    03-06-2015 06:20 PM
  13. Dankees's Avatar
    I just uninstalled Google+, restarted, re-installed it, and the error came up immediately. What the hell?!?!?!?!
    03-06-2015 06:31 PM
  1. Themes - what would you want?
    By the_stig#WN in forum Samsung Galaxy S6 edge
    Last Post: 03-10-2015, 11:46 AM
  2. Replies: 2
    Last Post: 03-08-2015, 07:43 PM
  3. how do I turn on speakerphone on my g3?
    By bruceb3 in forum LG G3
    Last Post: 03-06-2015, 07:39 PM
  4. Why am I unable to connect to Google?
    By redcloud1 in forum Ask a Question
    Last Post: 03-06-2015, 02:28 PM
  5. How do I transfer Pinerest from computer to my LG3?
    Last Post: 03-06-2015, 01:42 PM
