1. jeno27's Avatar
    going to buy gear 2 neo..does note 4 support gear. ..2 does anyone using..
    03-10-2015 07:25 AM
  2. honda-Dave's Avatar
    It should work with it, I have the gear S And the gear 1 running Tizen and they both work with my note 4.....
    Galaxy Note 4
    Galaxy Tab Pro 8.4
    Galaxy Tab 2
    Galaxy Gear S/ Gear 1 Tizen
    Galaxy Circle/ Gear Level speaker
    jeno27 likes this.
    03-10-2015 10:02 PM
  3. Brian W1's Avatar
    I'm using the Gear 2 with my Note 4. It works great. The only real difference between the Neo and Gear 2 is the sound and call ability, so you should be fine.
    jeno27 likes this.
    03-10-2015 10:41 PM
  4. jeno27's Avatar
    thank you guys..
    03-11-2015 07:56 AM
  1. Replies: 4
    Last Post: 04-05-2015, 12:15 PM
  2. Dead PIXEL on HTC Desire 816 , HELP!!!
    By Sam1911 in forum HTC Desire 816
    Last Post: 03-11-2015, 03:32 AM
  3. some advice needed, please
    By Pheelco in forum Ask a Question
    Last Post: 03-10-2015, 04:35 PM
  4. help sync data from s5 to tabs
    By Scott Fraser2 in forum General Help and How To
    Last Post: 03-10-2015, 12:49 PM
  5. Replies: 1
    Last Post: 03-10-2015, 12:46 PM
