1. AC Question's Avatar
    I have a request pop up to download a game and a notification pop up from my verizon cloud to enter my password, how can i block these two pop ups that are constanlty cluttering my screen?
    03-10-2015 04:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The game request is probably adware, which may have been installed along with some other app (likely a game) that you installed. You could try an app like Lookout's Ad-Network Scanner & Detector, but ultimately you may just have to uninstall apps one by one until it goes away.
    For the Verizon Cloud sign in, go to the App Manager, select Verizon Cloud, and see if you can Disable it. If you can't, then Clear Cache/Clear Data, and Force Stop it. Now don't open it again, and see if it stays dormant.
    03-11-2015 12:03 AM
  1. Replies: 7
    Last Post: 04-08-2015, 01:02 AM
  2. Replies: 2
    Last Post: 03-16-2015, 02:49 PM
  3. Replies: 1
    Last Post: 03-11-2015, 12:09 AM
  4. Why is my 4G LTE turned off when I turn my mobile data off?
    Last Post: 03-11-2015, 12:07 AM
  5. How do I update from ICS to Jelly Bean or KitKat?
    Last Post: 03-11-2015, 12:06 AM
