1. donebrasko's Avatar
    Am I the only one that gets really bad delayed text messages. Especially group
    03-10-2015 07:40 PM
  2. Android D's Avatar
    I would say so...lol
    I don't know which msg app you are using, but I have been using CHOMP SMS and I have no issues..5 months and this baby still doing good and I expect it for a LONG time to come..lol
    03-10-2015 09:25 PM
  3. donebrasko's Avatar
    I'm using the stock text messaging app. And there have been several times where I'm in a group message and I'm getting messages 30 later than everyone else
    03-12-2015 09:47 AM
  4. z06mike's Avatar
    Have you tried a 3rd party messaging app? In all honesty, the stock one SUCKS. Which carrier are you with?
    03-12-2015 10:32 AM
  5. mookiekillsit's Avatar
    I use Google Messenger and have this all the time. It's anything that has to do w/ MMS actually. If I am on WiFi, it will not work until I am on mobile data for some stupid reason.
    Do people w/ these third party apps have this issue or can they be downloaded automatically while on WiFi? I figured this was a Samsung limitation b/c while on my Moto X, this problem never occurred and I would get my group texts far faster than my GF who has a S3.
    03-12-2015 10:36 AM
  6. qbot101's Avatar
    That is what drove me away from the Google related apps. I HATE group messages, but I want to receive them in a timely manner. I ended on on Verizon Messages
    Sent from my SM-N910V
    Android D likes this.
    03-12-2015 01:26 PM
  7. donebrasko's Avatar
    Verizon
    03-16-2015 11:41 AM
  8. bobxxz's Avatar
    Recommend to switch to a different messenger. The stock one is laggy when it comes to MMS and etc. Try out chompSMS or Textra.
    03-16-2015 12:13 PM
  9. z06mike's Avatar
    Verizon
    Try out Verizon messages. It's a really cool app and handles group messaging very well!
    03-16-2015 02:39 PM
  10. mookiekillsit's Avatar
    Not gonna lie, I just switched from Google Messenger to this.... and I like it!!! Good job, Verizon!! Looks good, highly customizable, supposedly handles group messages well... like, I'm shocked that bloat apps are something I will use as my default.
    For real people, check this out.
    03-17-2015 08:57 AM
  11. z06mike's Avatar
    The funny this is that this isn't one of their "bloat" apps! If one of their apps should come installed on your phone it should be this one!
    03-17-2015 09:32 AM
  12. mookiekillsit's Avatar
    Well crap, I just got excited over nothing lol... but really, thanks for the heads up! While I enjoyed the clean look of Google Messenger, I didn't like how uncustomizable it was.
    03-17-2015 12:35 PM
  13. Therealm80's Avatar
    Sidebar question. I only use the stock messaging app because I can use the quick reply feature on my Gear watch. Does any of the other messaging apps allow you to do that on the Gear?
    03-17-2015 12:59 PM
  14. donebrasko's Avatar
    I'm using Google right now. I'll try Verizon's next
    03-19-2015 03:42 PM
  15. Anthony Valenti's Avatar
    Has anyone figured out how to fix this issue? I'm having the same problem on my HTC One M8 on T-Mobile. I've used the stock messaging app, Google Hangouts and Google Messenger and I will receive group MMS 20-30 minutes after everyone else receives them.
    09-06-2015 08:52 AM
  16. kirksucks's Avatar
    Group messages are mms and require mobile data.
    09-06-2015 03:38 PM
  17. Alex Wetzel's Avatar
    I'm not having any problems with MMS, and I use textra
    Sent from my SM-N910V using Tapatalk
    09-06-2015 08:05 PM
  18. jross0427's Avatar
    I have the same issue on my verizon Note 4. I get delays with all messaging apps. I'm about to try the Verizon app.. If it works with no delays, then I will blame verizon. Probably doing it on purpose so that everyone uses their app. It wouldn't surprise me.
    10-07-2015 10:00 AM
  19. Sean Dailey's Avatar
    This is driving me insane on my LG G4. A lot of my group messages get sent hours after I send them (show as "sending" for hours in the stock messaging app), and I also get delays receiving them.
    I tried the LG messaging app, Google's, and Textra. All 3 had the same issues.
    Trying Verizon messenger now to see if it helps.
    10-24-2015 09:10 PM
  20. fernandezhjr's Avatar
    My wife recently had a problem with her Note 4 not turning data on and off for MMS when on wifi. I suspect there could be multiple causes for this, but I was able to get this corrected for her by going to apps>all in the settings menu and clearing the caches for the Messages and MmsService apps and force stopping them. I also cleared data for the Messages app.
    10-27-2015 11:44 AM
  21. gsuaaron's Avatar
    Try chomp app. I did on att and it fixed my messages being delayed prob
    huntnyc likes this.
    12-31-2015 10:49 PM
  22. lionelwong888's Avatar
    To fix this, I opened my Messaging App then go to "Settings", Scroll down to "Group Conversations:, uncheck box that says "Use MMS to start group conversations".....it should work. It works for me.
    09-01-2017 12:02 AM
  1. Replies: 1
    Last Post: 05-09-2015, 08:04 AM
  2. Replies: 7
    Last Post: 04-08-2015, 01:02 AM
  3. Replies: 4
    Last Post: 03-16-2015, 05:45 PM
  4. Replies: 1
    Last Post: 03-11-2015, 12:09 AM
  5. Replies: 1
    Last Post: 03-11-2015, 12:00 AM
