Haalcyon
Banned
Have you disabled the AT&T bloat? I always do and am very satisfied with the battery life:
All of those things need to be indexed. One bad ID3 tag on a song or one corrupted picture can cause a loop in the indexing service that may cause indexing to run at 100% until the bad file is removed.
If you take the card out and the problem persists, then it's not the card.
If you take the card out and the problem goes away, then either you got a bad card (even new ones can be bad sometimes) or one of the files you copied to it has a problem that Android just does not like at all.
The hard part about tracking something like this down is simply that the service covers a great many tasks, and any one of them could be causing it. Simple things like pulling the card allow you to narrow down the problem quickly.
This indexing issue with damaged files has been around a long time - I ran into it with an older device and a PDF file. I would have thought that the OS would do a couple of tries then give up on the offending file and move on, having tagged that file with an ignore flag or something similar. A corrupt user file like that should not lead to continuous poor performance like it does.
I can't seem to figure out why this battery is draining so fast it's awful I have to charge it three times a day...it drains two percent every ten minutes or so..it's brutal...I'm not even using it..it sits on my desk all day at work except to check texts and what not...anyone have an idea why this is happening..it's a brand new unlocked ATT phone...only two weeks in...I don't get why it's happening and it's aggravating...any help appreciated...thank you
If that's what you use it for, disable sync and data when not in use, clear running app from time to time. My battery drains 1-2% overnight.
@T-Mobile GN3
Well you also have a different carrier as well..not sure if that matters...
