03-13-2015 11:26 AM
29 12
tools
  1. mlbyanks11's Avatar
    I can't seem to figure out why this battery is draining so fast it's awful I have to charge it three times a day...it drains two percent every ten minutes or so..it's brutal...I'm not even using it..it sits on my desk all day at work except to check texts and what not...anyone have an idea why this is happening..it's a brand new unlocked ATT phone...only two weeks in...I don't get why it's happening and it's aggravating...any help appreciated...thank you
    Attached Thumbnails battery drain is awful and frustrating-screenshot_2015-03-12-10-51-28.jpg
    03-12-2015 09:55 AM
  2. natehoy's Avatar
    Have you looked at what apps are using battery? There's a lot of "awake" time going on there, particularly with WiFi off.
    03-12-2015 10:00 AM
  3. mlbyanks11's Avatar
    How can you determine that?..I've tried plenty and can't figure it out
    03-12-2015 10:06 AM
  4. muzzy996's Avatar
    Right off the bat as natehoy says the screen shot depicts an issue with an application or service running constantly in the background (as evident by the awake bar being solid blue while the screen bar shows screen is off at times). Your signal strength is also marginal most of the time. Couple the two issues and its no wonder that battery life is poor.
    Look at the battery stats pages more closely and examine what applications rank near the top. It also may not hurt to reboot into recovery and clear cache.
    03-12-2015 10:09 AM
  5. mlbyanks11's Avatar
    You tell me what's running in the background at a high percentage because besides Android system I don't see anything other than that causing the battery to drain...it's awful
    Attached Thumbnails battery drain is awful and frustrating-screenshot_2015-03-12-11-20-09.jpg
    03-12-2015 10:21 AM
  6. doohsun's Avatar
    i notice that you have blackberry app i removed mine right away i notice how much battery it's draining. What's the one right next too it?
    03-12-2015 10:25 AM
  7. muzzy996's Avatar
    I would do a cache clear first by rebooting into recovery (turn the phone off, pull the battery for a few seconds to be sure, replace the battery, hold HOME & VOLUME UP while depressing POWER until the boot screen comes up and releasing POWER while holding the other two a little longer). I'd then let the device boot up, leave it untouched for a half hour and return to the battery stats graph screen to see if the awake bar is still solid blue for the period that the screen is off. If it is then start uninstalling unnecessary utility applications and widgets systematically starting with any memory management, cleaning or battery monitoring apps.
    03-12-2015 10:41 AM
  8. mlbyanks11's Avatar
    Its Juice defender...been using it for years...the only battery save app i've ever used
    03-12-2015 10:55 AM
  9. doohsun's Avatar
    i tried that before and got rid of it have you tried Dr Battery? i really like Dr battery i can schedule my phone usage at night so every night since i'm sleeping at 11:00pm for example i turn off wifi, bluetooth, sync and when i wake up i turn i those back on. I get my phone through 2 full days
    03-12-2015 10:59 AM
  10. mlbyanks11's Avatar
    Well I like to have things on...I came from Verizon and the battery on that variant was great...ATT version I dont know whats wrong...I will look into that app but not getting my hopes up lol...thanks for the though..
    03-12-2015 11:07 AM
  11. natehoy's Avatar
    "Android System" is frequently associated with either syncing or indexing. Certainly not always, but it's worth starting there.
    Do you have an SD card on board? Pull that card for a while and see if that helps. If it does, you either have a lot of stuff on that SD or you may have a bad card.
    Do you have G+ backing up your pictures? Make sure this is only happening on WiFi if you can, and hit "back up now" while on WiFi and see if it finishes in what seems like a reasonable time (which depends on the number of pictures/videos you have). If it does not, you may have a corrupted picture or something.
    03-12-2015 11:12 AM
  12. KahneFan's Avatar
    Low signal will eat a battery fast! With my Note 2, I had excellent battery life... until I went to work. I was in an all metal building and it KILLED my signal. I would be at 95% at 8:00 AM and 10% by 12:00 PM. I [maybe] would get 1 bar the entire time I was at work. I had to leave it on the charger most of the day. However, as soon as I drove home, the battery would stop draining.
    03-12-2015 12:01 PM
  13. mlbyanks11's Avatar
    Well I get great reception where I work and the SD card is brand new and not defective...IDK where that came from but both phone and SD card are fairly new...used the same card in my Verizon note 4 and had switched to att and needed there variant..since then it's been awful I can't even get eight hours out of my battery it's not acceptable
    03-12-2015 12:58 PM
  14. muzzy996's Avatar
    Actually you don't get great reception, the mobile network signal bar on the attached image in your first post proves it since there's a short bit of green initially and then 95% of the time the bar is mustard colored. That color designation means lower signal, red means no signal.
    It is best to start logically and systematically to figure out what the issue is. The long wake times is the key right now so try to start there first by clearing cache and testing for wake time. If the device goes to deep sleep after a cache clearing (in recovery, not using some random play store app to do it) then you're golden but if not then move on to the next thing such as pulling the microSD card and retesting . . . after that, try uninstalling utilities.
    03-12-2015 01:38 PM
  15. mlbyanks11's Avatar
    It's not the SD card it's brand new...128gb memory card...IDK why there's so much wake time and I get good reception mainly everywhere I go...I don't care what some color bars tell me about my reception seriously...
    Attached Thumbnails battery drain is awful and frustrating-screenshot_2015-03-12-14-46-21.jpg
    03-12-2015 01:49 PM
  16. Golfdriver97's Avatar
    The gap would indicate you rebooted, and it looks like it helped. I agree with the cache clear in recovery.
    The SD card may be new, but if the OS is having a hard time reading a file, that can cause a wake lock.
    From an AOSP M8
    03-12-2015 01:56 PM
  17. mlbyanks11's Avatar
    From an AOSP M8
    Believe it or not I already did that...
    03-12-2015 02:08 PM
  18. natehoy's Avatar
    It's a brand new card but is there anything on it?
    Try removing the card for a day, just as a test, and see if the problem goes away.
    03-12-2015 02:48 PM
  19. mlbyanks11's Avatar
    Besides my pictures and music and ringtones... That's it...
    03-12-2015 02:54 PM
  20. natehoy's Avatar
    All of those things need to be indexed. One bad ID3 tag on a song or one corrupted picture can cause a loop in the indexing service that may cause indexing to run at 100% until the bad file is removed.
    If you take the card out and the problem persists, then it's not the card.
    If you take the card out and the problem goes away, then either you got a bad card (even new ones can be bad sometimes) or one of the files you copied to it has a problem that Android just does not like at all.
    The hard part about tracking something like this down is simply that the service covers a great many tasks, and any one of them could be causing it. Simple things like pulling the card allow you to narrow down the problem quickly.
    03-12-2015 03:01 PM
  21. Haalcyon's Avatar
    Have you disabled the AT&T bloat? I always do and am very satisfied with the battery life:
    Attached Thumbnails battery drain is awful and frustrating-1426190808549.jpg   battery drain is awful and frustrating-1426190907250.jpg   battery drain is awful and frustrating-1426190925704.jpg   battery drain is awful and frustrating-1426190942347.jpg   battery drain is awful and frustrating-1426190955620.jpg
    03-12-2015 03:09 PM
  22. sparksd's Avatar
    This indexing issue with damaged files has been around a long time - I ran into it with an older device and a PDF file. I would have thought that the OS would do a couple of tries then give up on the offending file and move on, having tagged that file with an ignore flag or something similar. A corrupt user file like that should not lead to continuous poor performance like it does.
    03-12-2015 03:23 PM
  23. mlbyanks11's Avatar
    Believe it or not I do have a few ringtones that don't play..now that you mention it
    03-12-2015 03:25 PM
  24. muzzy996's Avatar
    Try installing Better Battery Stats and see if it can shed some light on wakelocks.
    I'm not sure why but rather than improve battery use statistics google has reduced the usefulness of battery stats in Android. It's much easier to determine what's wrong with root but without it it's next to impossible sometimes.
    03-13-2015 12:16 AM
  25. mlbyanks11's Avatar
    Now look at it..better but still shouldn't drain this bad while I'm sleeping
    Attached Thumbnails battery drain is awful and frustrating-screenshot_2015-03-13-07-24-24.jpg
    03-13-2015 06:26 AM
29 12
  1. Help With Custom Ringtones and Message Alerts
    By Dankees in forum Samsung Galaxy Note 4
    Last Post: 03-20-2015, 06:11 PM
  2. Does G3 buttons and body wear off?
    By crunchor in forum LG G3
    Last Post: 03-13-2015, 01:52 PM
  3. Replies: 1
    Last Post: 03-12-2015, 10:54 AM
  4. Maintain text format when copying and pasting?
    Last Post: 03-12-2015, 08:15 AM
  5. Is there a way to add contact specific Text Tones????
    Last Post: 03-12-2015, 08:14 AM
