1. Juriaan727's Avatar
    Hey all,
    This is my first day with my note 4 and I was wondering if my battery stats are standard or if something is wrong. I did have my screen brightness on pretty strong (screen takes up 63%).
    The phome went off the charger at 7 am and ita now 12 pm and my battery is at 25%. I do use my phone a lot ( the screen on time at the moment is 3h 22 mins). I do game a lot (about 1hr of the ost is gaming).
    Any ideas guys? I will try and attach a screenshot of the battery.
    Thank you in advance!
    03-16-2015 06:09 AM
  2. Juriaan727's Avatar
    I attached the screenshot.
    03-16-2015 06:15 AM
  3. neils0911's Avatar
    Unfortunately this is normal and if youve been gaming for an hour on high brightness then you've done quite well. The note 4 has a qhd screen remember which is a huge power hog on high brightness.
    03-16-2015 06:27 AM
  4. LaTuFu's Avatar
    The higher you go on screen brightness, the faster your battery drain.
    Your performance looks pretty normal for the use you describe.
    03-16-2015 06:44 AM
  5. dpham00's Avatar
    Agreed. Normal for the usage described.
    Sent from my Verizon Samsung Galaxy Note 4
    03-16-2015 10:48 AM
  1. High battery usage on Galaxy Note 8.0
    By Brahmanda Gede in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 03-21-2015, 07:10 PM
  2. Replies: 28
    Last Post: 03-16-2015, 09:29 PM
  3. Why is my battery draining so fast Android 5.0.2?
    Last Post: 03-16-2015, 06:14 AM
  4. viber is not working in my xperia z!
    Last Post: 03-16-2015, 02:18 AM
  5. How do I unlock my Blu Life play?
    Last Post: 03-16-2015, 02:09 AM
