1. schnebbles's Avatar
    Ok, so which is it that provides the actual faster charge? the usb cable or the plug? I just got note 4 and want extra chargers.
    I have lots of wall plugs from my note 3 - can I use them with fast charge usb cords? I was going to buy some oem stuff on ebay but wasn't sure just which pieces I really need.
    thanks!
    03-18-2015 12:34 AM
  2. Brian W1's Avatar
    It's the plug. I just bought one last week.
    03-18-2015 12:37 AM
  3. Mr. Toad's Avatar
    thanks!
    It is the wall plug. Any of the products that say Qualcomm Quick Charge 2.0 should work.
    03-18-2015 12:41 AM
  4. schnebbles's Avatar
    Thanks! Brian where did you get it?
    03-18-2015 12:47 AM
  5. Rukbat's Avatar
    Samsung Galaxy Note 4 Chargers & Cables - ShopAndroid has one fast charge wall charger and one fast charge car charger.
    Kjthomas0724 likes this.
    03-18-2015 08:30 PM
  6. ihbsbA's Avatar
    I have a 2.1 amp car charger and I never get the fast charge message... I figured it was the cable in that instance.
    03-19-2015 09:54 AM
  7. dpham00's Avatar
    5v/2a doesn't display fast charging. Only when charging using qualcomm quick charge 2.0 would it display fast charging - 9v @ 1.67a,or higher voltage.
    Sent from my Verizon Samsung Galaxy Note 4
    03-19-2015 10:31 AM
  8. Kjthomas0724's Avatar
    Found this on Amazon. Wonder if it's worth trying out.
    http://www.amazon.com/gp/aw/d/B00TDC...cUvbUpU4293710
    03-19-2015 03:33 PM
  9. dpham00's Avatar
    http://www.amazon.com/gp/aw/d/B00TDC...cUvbUpU4293834
    I wouldn't trust it. Too many 5 star reviews in a short time
    03-19-2015 04:38 PM
  10. schnebbles's Avatar
    I'd try it for $10
    03-19-2015 05:14 PM
  1. Replies: 3
    Last Post: 04-16-2015, 03:51 PM
  2. How Do Different Launchers Effect The Edge Screen?
    By Wildo6882 in forum Samsung Galaxy Note Edge
    Last Post: 03-30-2015, 11:54 AM
  3. Replies: 1
    Last Post: 03-17-2015, 10:55 PM
