1. AC Question's Avatar
    I use es file explorer and often can't copy,move,delete files from my external sd card or from internal to external .a lot of time sistem said I don't have right to do that
    03-18-2015 10:11 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! ES File Explorer should have the proper SD permissions. Can you use it to create a new directory on the SD card?
    03-18-2015 05:26 PM
  3. dpham00's Avatar
    If you are on KitKat then you will need to use the stock my files app to write to the sd card. Es won't do it. I believe that this is fixed in lollipop. This isn't a Galaxy problem, many Androids on KitKat have this issue m
    Sent from my Verizon Samsung Galaxy Note 4
    03-19-2015 09:36 AM
  4. lterry913's Avatar
    I would love to know for sure if anyone who gets lollipop has this capability. I really miss being able to move things to my card.
    Karma Lotus likes this.
    03-19-2015 02:01 PM
  5. Karma Lotus's Avatar
    Seems to me that the true problem is that it is more desirable that we use cloud services for transferring files instead of SD cards. Everything in the cloud can be read by Uncle Sam and stored in Utah.
    03-28-2015 01:35 AM
  6. plumcrazy's Avatar
    i agree but if uncle sam wants to see my d*** pics, he's welcome to it lol
    03-28-2015 05:23 AM
  7. sparksd's Avatar
    Yes, I have done it repeatedly using ES File Explorer running on Lollipop. No problems.
    03-28-2015 08:04 AM
  8. angel220's Avatar
    You can transfer files from device to SD card using the my files folder, no need for an app.
    03-28-2015 08:36 AM
  1. Samsung Galaxy S6 How replaceable is the battery?
    By oscarnyc in forum Samsung Galaxy S6
    Last Post: 03-19-2015, 09:13 PM
  2. Replies: 1
    Last Post: 03-18-2015, 05:31 PM
  3. Why is my sim puk blocked?
    By AC Question in forum Samsung Galaxy Core
    Last Post: 03-18-2015, 01:04 PM
  4. Replies: 1
    Last Post: 03-18-2015, 10:02 AM
  5. Replies: 0
    Last Post: 03-18-2015, 08:29 AM
