1. AC Question's Avatar
    Phone rings, cannot answer as phone appears to be locked. Have to wait then call the caller back to make a connection
    03-18-2015 11:42 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you say the phone appears to be locked, do you mean that you see a screenlock and have to enter a password or PIN to try to answer the phone? Or do you mean it freezes up no matter what you're doing when a call comes in, and you can't answer it?
    03-18-2015 05:03 PM
  3. binarymath's Avatar
    I had to do a full reset this week, and now I have a similar problem.
    The phone rings as normal, and gives me the choice of answer or cancel. The touch screen lights up when I hit either button. But it does not process the command to actually ANSWER the call. Same thing happens when I set an alarm; cannot snooze or cancel.
    any suggestions are welcome, but it looks like I am headed toward another reset.
    08-10-2015 07:03 PM
  1. Replies: 3
    Last Post: 05-08-2016, 01:39 AM
  2. When will Lollipop come to the Verizon Note 4?
    By shawninut in forum Samsung Galaxy Note 4
    Last Post: 03-21-2015, 01:57 PM
  3. What's the easiest and free way to save voicemails from my Android Note?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-18-2015, 11:29 PM
  4. Galaxy S5 Video App
    By neil154 in forum Samsung Galaxy S5
    Last Post: 03-18-2015, 09:28 PM
  5. Hi ! I got my new phone Flare S3 Octa core, how can I Go sms Pro to work?
    Last Post: 03-18-2015, 05:12 PM
