Multi view window not working since lollipop update.
iamtybaby
16
Every since i updated to L...my multi windows button doesn't work anymore....is there a new to do it now? I used to hold the loop arrow looking thing down and it would bring up options for a 2nd screen...doesn't do that anymore
willanaya
124
I am having the same problem. I would activate the multiwindow and then the multiwindow will show itself but after I close it, it will no longer appear.
wana10
I am having this issue too....multi-window switch is enabled, but the button to open the split window no longer appears. I have noticed that a new update (5.1) has already rolled out, does it address this issue? When is north america scheduled to have it?
Bam Bi
open google app, click the three dots options on your phone (upper right). Select "settings", turn off "merge tabs and apps".
There you go, you can view your opened tabs now.
ibnumanickam
3
multi window is now showing on right side after 5.0 update i've tried every possible way to bring it back is this a bug i've re initiated my device using smart switch still has the problem please any one help cc74b754-07fa-4ac0-9e32-17fd6945c1c8.jpg
axool
