1. Savan01's Avatar
    Hello, I've had my note 4 since Christmas of 2014 and for the first month or so my battery was reallly good like I could get 6 minutes of usage from 1% and then I slowly noticed my battery was getting worse and worse and not its pretty bad. Like a minute or 2 from 1% and I was wondering if my batteries faulty or if I should get a new one. Also how can I post a image so I can share my battery performance?
    03-22-2015 12:54 PM
  2. latinking91's Avatar
    Go to settings and then go to power saving your apps should show up how much battery they using. Then you can click on the graph to see more details
    Posted via My Note 4
    Attached Thumbnails Note 4 battery life??-screenshot_2015-03-16-19-04-19.jpg
    03-22-2015 02:05 PM
  3. latinking91's Avatar
    The first screenshot is wrong. Sorry.
    Attached Thumbnails Note 4 battery life??-screenshot_2015-03-22-11-04-53.jpg
    03-22-2015 02:06 PM
  4. Savan01's Avatar
    I know that, I wanna know how I can post my screen shot
    03-22-2015 06:14 PM
  5. clevin's Avatar
    Battery degrades over time, but not this fast.
    You should try a cache wipe and reboot a few times. Disable sync and turn off data when not in use.
    If these don't fix for you, consider buying another battery.
    03-22-2015 06:53 PM
  6. Savan01's Avatar
    lmfaoooo so I cleared the cache and the phone performs alot better but the battery is still the same, it might've gotten worse. I think I'm gonna drain the battery and review it's performance tomorrow in the field
    03-22-2015 09:27 PM
  7. dpham00's Avatar
    http://forums.androidcentral.com/gen...tos-forum.html
    Sent from my Verizon Samsung Galaxy Note 4
    03-23-2015 12:37 AM
  8. Savan01's Avatar
    So I cleared the cache and my battery performance is still terrible
    03-26-2015 08:25 PM
  9. Savan01's Avatar
    my battery stats
    03-26-2015 08:31 PM
  10. Savan01's Avatar
    my battery stats
    03-26-2015 08:32 PM
  11. itguyjax8430's Avatar
    Are you rooted?
    03-26-2015 08:37 PM
  12. Savan01's Avatar
    nope, i don't plan to root anytime soon
    03-26-2015 08:38 PM
  13. Savan01's Avatar
    nope, i don't plan to be anytime soon.
    03-26-2015 08:39 PM
  1. Note Edge or Note 4?
    By Cool Jeff in forum Samsung Galaxy Note Edge
    Last Post: 04-06-2015, 02:33 PM
  2. Replies: 6
    Last Post: 03-27-2015, 12:09 AM
  3. Nexus 5 Upgrade/Battery
    By blissofdeath in forum Google Nexus 5
    Last Post: 03-25-2015, 09:16 PM
  4. Why is Cocktailbar service draining my battery?
    Last Post: 03-22-2015, 04:17 PM
  5. Replies: 0
    Last Post: 03-22-2015, 08:07 AM
