1. jakeypride's Avatar
    How do I get my Itunes onto my new note 4? Im about to cry!!!
    03-24-2015 01:27 AM
  2. Jay Sacks's Avatar
    I am surprised you have yet to be rescued. I have read many threads to accomplish this. Maybe you can run a search with those key words. If not, someone will come shortly I am sure. Good luck.
    03-24-2015 01:55 AM
  3. nemopsp's Avatar
    What I did I took 64gb sd card an copied all music on it but also some music won't play, so I've uploaded all the music to Google play and now it all works and you just download it, but I recommend uploading to Google play on Pc use program Music Manager, I'm sure you can find it on Google I found it pretty fast
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    03-24-2015 02:17 AM
  4. Andrew Read1's Avatar
    I just dragged and dropped from iTunes on to sd card
    03-24-2015 03:15 AM
  5. jakeypride's Avatar
    i cant figure it out
    03-24-2015 04:13 AM
  6. doctordwaynewilliams's Avatar
    This worked?
    03-24-2015 04:18 AM
  7. anon(8413510)'s Avatar
    Easy :-)
    Posted from België using my Note 4
    03-24-2015 05:46 AM
  8. Andrew Read1's Avatar
    Yeah I opened my sd card, then opened iTunes selected all tracks and dragged them across to the sd card. All works fine on my note 4. I'm in the UK so not sure if iTunes works differently
    03-24-2015 06:01 AM
  9. anon67808's Avatar
    Couldn't tell you. Never used iTunes, never will use iTunes.
    03-24-2015 11:25 AM
  10. keyzlife's Avatar
    I used google play music manager. It transfers perfectly. It did for me anyway. Plus if you leave it installed on your pc or Mac, it will automatically add any new iTunes purchases.
    https://support.google.com/googlepla.../1229970?hl=en
    Hope that helped.
    sent from my Samsung GALAXY Note® 4
    03-24-2015 01:13 PM
  11. tlo07's Avatar
    iSyncr use to be my go-to software for transferring iTunes music to my Androids but for some reason I just couldn't get it to work with my Note 4. I tried DoubleTwist and that worked just fine. I like to use an app that keeps my playlists intact instead of dragging and dropping.
    03-24-2015 01:21 PM
  12. Glenn Sager's Avatar
    Thanks for answering his question in such a helpful manner. I am really glad that I now know that you have never, ever, ever used iTunes.
    You cannot actually get iTunes on an android phone. You can get most of your music in a few ways. As some have said, you could just drag the music files to your phone or sd card. There are also a few apps that will let you transfer the music and playlists. iSyncr and Doubletwist are 2 that I can think of off the top of my head.
    03-24-2015 03:31 PM
  13. anon67808's Avatar
    Of course there's always one in the group who blows stuff way out of proportion.
    03-24-2015 03:41 PM
  14. jakeypride's Avatar
    I finally got it by doing it through google play manager, however some of the albunm covers didnt go through.
    03-24-2015 10:01 PM
  1. [Closed] Help us 3D Print some Lloyd gear in this week's contest!
    By Russell Holly in forum Android Central Contests
    Last Post: 04-01-2015, 06:49 AM
  2. Replies: 24
    Last Post: 03-26-2015, 03:33 PM
  3. Desire 816 help I'm gonna cry
    By Nick Harshaw in forum HTC Desire 820
    Last Post: 03-24-2015, 07:36 AM
  4. Lost Complete Data and Need help in getting it back
    By prarjun1990 in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 03-24-2015, 01:03 AM
  5. Help! Looking which phone should I upgrade?
    Last Post: 03-23-2015, 03:51 PM
